Full Version: Rotated text in grouplist
I have some rotated text in a vertical grouplist and when scrolling up and down they get cut off incorrectly (i.e. as if they were not rotated).
http://i.imgur.com/TleDAUH.png
These labels should describe the group or panel next to it. As i wish to add more then recent tv and movie.
http://i.imgur.com/BatGItp.png
So i was trying to think of a way around it. Like keeping the label in place and changing the string.
But how would i know which control is the top one visible?
Or is there a better way?
I gave it a spin and tried to build a grouplist with rotated labels on the side (kind of what I imagine You'd like to acheive give the pictures), and everything worked as supposed.
this is how I built it:
<grouplist vertical>
  <group (i.e. movies)>
    <rotated label>
    <list horizontal>
    </list>
  </group>
  <group (i.e. tvshows)>
    <rotated label>
    <list horizontal>
    </list>
  </group>
</grouplist>
hope that makes sense, and is of help.
And you are not getting these problems i marked in this image?
http://i.imgur.com/m3FvZTU.png
I have a skin with groups that started messing on the 9th too. Do you find major differences based on the screen size? Mine change completely when I go full screen, almost like the 1280x720 base is getting lost.
Martin
(2013-11-12, 05:01)MassIV Wrote: [ -> ]And you are not getting these problems i marked in this image?
nope.
any chance I can peek @ your code?
Sure, probably easiest to grab this repo:
https://code.google.com/p/skin-git/downloads/list
You need:
Home.xml id="4000"
Includes_Metroid.xml
EDIT: Slowed everything down and actually you're right. the labels are computed before rotation.
