Full Version: boblight error
hello, i have boblight error on starup:
script failed script.xbmc.boblight
log:
12:57:22 T:2679376704 NOTICE: -->Python Interpreter Initialized<--
12:57:22 T:2806119232 NOTICE: Thread Background Loader start, auto delete: false
12:57:22 T:2679376704 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'module' object has no attribute 'scriptID'
File "/home/robert/.xbmc/addons/script.xbmc.boblight/default.py", line 37, in <module>
from settings import *
File "/home/robert/.xbmc/addons/script.module.sd-xbmc/lib/settings.py", line 5, in <module>
import pLog
File "/home/robert/.xbmc/addons/script.module.sd-xbmc/lib/pLog.py", line 4, in <module>
scriptID = sys.modules[ "__main__" ].scriptID
AttributeError: 'module' object has no attribute 'scriptID'
12:57:33 T:2679376704 NOTICE: Thread Background Loader start, auto delete: false
12:57:42 T:2679376704 NOTICE: Previous line repeats 3 times.
12:57:42 T:2679376704 NOTICE: Thread XBPyThread start, auto delete: false
12:57:42 T:2679376704 NOTICE: -->Python Interpreter Initialized<--
default.py file:
# -*- coding: utf-8 -*-
Boblight for XBMC
Copyright © 2012 Team XBMC
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
import xbmc
import xbmcaddon
import xbmcgui
import os
__addon__ = xbmcaddon.Addon()
__cwd__ = __addon__.getAddonInfo('path')
__scriptname__ = __addon__.getAddonInfo('name')
__version__ = __addon__.getAddonInfo('version')
__icon__ = __addon__.getAddonInfo('icon')
__ID__ = __addon__.getAddonInfo('id')
__language__ = __addon__.getLocalizedString
__profile__ = xbmc.translatePath( __addon__.getAddonInfo('profile') )
__resource__ = xbmc.translatePath( os.path.join( __cwd__, 'resources', 'lib' ) )
sys.path.append (__resource__)
from tools import *
log( "[%s] - Version: %s Started" % (__scriptname__,__version__))
capture_width = 32
capture_height = 32
settings = settings()
class MyPlayer( xbmc.Player ):
def __init__( self, *args, **kwargs ):
xbmc.Player.__init__( self )
self.playing = False
log('MyPlayer - init')
def onPlayBackStopped( self ):
myPlayerChanged( 'stop' )
def onPlayBackEnded( self ):
def onPlayBackStarted( self ):
self.playing = True
myPlayerChanged( 'start' )
def isPlaying( self ):
return self.playing
class MyMonitor( xbmc.Monitor ):
xbmc.Monitor.__init__( self )
log('MyMonitor - init')
def onSettingsChanged( self ):
settings.start()
if not settings.reconnect:
check_state()
def onScreensaverDeactivated( self ):
settings.screensaver = False
settings.handleStaticBgSettings()
def onScreensaverActivated( self ):
settings.screensaver = True
class Main():
self.warning = 0
def connectBoblight(self):
bob.bob_set_priority(255)
if settings.hostip == None:
log("connecting to local boblightd")
else:
log("connecting to boblightd %s:%s" % (settings.hostip, str(settings.hostport)))
ret = bob.bob_connect(settings.hostip, settings.hostport)
if not ret:
log("connection to boblightd failed: %s" % bob.bob_geterror())
text = __language__(500)
if self.warning < 3 and settings.other_misc_notifications:
xbmc.executebuiltin("XBMC.Notification(%s,%s,%s,%s)" % (__scriptname__,text,750,__icon__))
self.warning += 1
settings.reconnect = True
settings.run_init = True
settings.force_update = True
return False
else:
self.warning = 0
if settings.other_misc_notifications:
text = __language__(501)
log("connected to boblightd")
bob.bob_set_priority(128)
return True
def startup(self):
platform = get_platform()
libpath = get_libpath(platform)
loaded = bob.bob_loadLibBoblight(libpath,platform)
if loaded == 1: #libboblight not found
if platform == 'linux':
t1 = __language__(504)
t2 = __language__(505)
t3 = __language__(506)
xbmcgui.Dialog().ok(__scriptname__,t1,t2,t3)
else: # ask user if we should fetch the
t1 = __language__(504) # lib for osx, ios and windows
t2 = __language__(509)
if xbmcgui.Dialog().yesno(__scriptname__,t1,t2):
tools_downloadLibBoblight(platform,settings.other_misc_notifications)
elif loaded == 2: #no ctypes available
t1 = __language__(507)
t2 = __language__(508)
xbmcgui.Dialog().ok(__scriptname__,t1,t2)
return loaded
def check_state():
if xbmc.Player().isPlaying():
state = 'start'
else:
state = 'stop'
myPlayerChanged( state )
def myPlayerChanged(state):
log('PlayerChanged(%s)' % state)
xbmc.sleep(100)
if state == 'stop':
ret = "static"
else:
if xbmc.getCondVisibility("VideoPlayer.Content(musicvideos)"):
ret = "musicvideo"
elif xbmc.getCondVisibility("Player.HasAudio()"):
ret = "static"
else:
ret = "movie"
if settings.overwrite_cat: # fix his out when other isn't
if settings.overwrite_cat_val == 0: # the static light anymore
ret = "movie"
else:
ret = "musicvideo"
settings.handleCategory(ret)
def run_boblight():
main = Main()
xbmc_monitor = MyMonitor()
player_monitor = MyPlayer()
player_monitor.playing = xbmc.Player().isPlaying()
if main.startup() == 0:
capture = xbmc.RenderCapture()
capture.capture(capture_width, capture_height, xbmc.CAPTURE_FLAG_CONTINUOUS)
while not xbmc.abortRequested:
xbmc.sleep(100)
if not settings.bobdisable:
if not bob.bob_ping() or settings.reconnect:
if not main.connectBoblight():
continue
if settings.bob_init():
check_state()
settings.reconnect = False
if not settings.staticBobActive:
capture.waitForCaptureStateChangeEvent(1000)
if capture.getCaptureState() == xbmc.CAPTURE_STATE_DONE and player_monitor.isPlaying():
width = capture.getWidth();
height = capture.getHeight();
pixels = capture.getImage();
bob.bob_setscanrange(width, height)
rgb = (c_int * 3)()
for y in range(height):
row = width * y * 4
for x in range(width):
rgb[0] = pixels[row + x * 4 + 2]
rgb[1] = pixels[row + x * 4 + 1]
rgb[2] = pixels[row + x * 4]
bob.bob_addpixelxy(x, y, byref(rgb))
if not bob.bob_sendrgb():
log("error sending values: %s" % bob.bob_geterror())
return
else:
log('boblight disabled in Addon Settings')
continue
del main #cleanup
del player_monitor
del xbmc_monitor
if ( __name__ == "__main__" ):
run_boblight()
bob.bob_set_priority(255) # we are shutting down, kill the LEDs
bob.bob_destroy()
please help
It's because of script.module.sd-xbmc. read this.
