Full Version: Remove video from library then delete?
Sorry I am an XBMC newbie. Unless I was dreaming it, I know I saw an option to delete the file after it was removed from the library. It was a second yes / no dialog box that displayed after the confirmation to remove from library. I cannot remember the exact text but basically it was asking if you wanted to remove the actual file. Now I am not seeing that second question.
Is there any way to remove a video from xbmc and delete it?
Yep, just enable file deletion. XBMC -> Settings -> Appearance -> File lists -> "Allow file renaming and deletion"
Then it will ask if you also want to delete when you remove from library.
That was it thanks Ned. I must have fat fingered the setup menu and turned the feature off at some point,
