2013-11-16, 08:25
Hi!
I have a constant buffering problem when streaming media from Internet sources. My speed is at about 6 MBps (60 to 80 Mbps) down so there shouldn't be an issue. Video playback is great for local media, however I've noticed youtube or Vevo plugins in xbmc buffer so bad it hangs. I added the "0' value to my advancedsettings.xml file to make sure I can have plenty of buffer, and that helps on Youtube if I pause for a while before watching, but Vevo doesnt use that settings (because it counts as music?).
debug:
http://xbmclogs.com/show.php?id=85492
I see this occur a lot in the xbmc.log:
debug:
22:20:04 T:140408078153472 DEBUG: Suspended the Sink
22:20:53 T:140405551126272 DEBUG: CDVDPlayer::SetCaching - caching state 4
22:20:53 T:140405425301248 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
22:20:53 T:140408078153472 INFO: CAESinkALSA::Initialize - Attempting to open device "default"
22:20:53 T:140405416908544 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:202486088.818263, should be:196881978.140263, error:-5604110.678000
22:20:53 T:140408078153472 INFO: CAESinkALSA::Initialize - Opened device "default"
22:20:53 T:140408078153472 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2205, bufferSize 8820
22:20:53 T:140408078153472 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2205, bufferSize 8820
22:20:53 T:140408078153472 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
22:20:53 T:140408078153472 DEBUG: Resumed the Sink
22:20:53 T:140408078153472 DEBUG: CSoftAE::Run - Sink restart flagged
22:20:53 T:140408078153472 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 44100hz
22:20:53 T:140408078153472 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.1
22:20:53 T:140408078153472 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 17640
22:20:53 T:140405425301248 DEBUG: CPullupCorrection: pattern lost on diff -5421791.666668
22:20:53 T:140405551126272 DEBUG: CDVDPlayer::SetCaching - caching state 0
22:20:53 T:140408332769152 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
22:20:58 T:140405425301248 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333
