Full Version: Manually add content into library
Hi
What's the best way to manually add content to my XBMC library ?
For some shows, the stuff on TVDB is too different ... or is simply not there.
This is mostly for local / children shows , and I don't want too waste too much time on it, so episode names & a picture is just fine...
Is there a program or such which can generate local artwork which XBMC will pick up and add to the library ?
Thanks for your suggestions
Hi
Could I use something like Ember Media Manager to set up local nfo/tbn's ?
Or do I need to create these all from scratch as described in :
http://www.pcmediacenter.com.au/forum/to...nfo-files/
