I've just installed the Arctic XBMB3C skin
https://github.com/elcabong/skin.arctic-xbmb3c
And even that doesn't have any movies or TV shows listed. I must be doing something wrong somewhere
1. Install XBMC 12.3
2. Install XBMB3C plugin 0.8.5
3. Configure XBMB3C with Media Browser settings - Server name, Username and password. This is confirmed by launching the app and it shows me my movies.
4. Install skin and go back to home page.
Movies and TV Shows are not listed. 0 found.
I just installed this, but i there seems to be no favorite TV shows...is this normal? There is favorite Movies and episodes but no TV shows. Really cant use this plugin without that because the wife just hates to have to scrool 200+ Tv shows and i had created a favorites in the MBS hoping to use it in xbmc.
OFark,
in arctic-xbmb3c, you need to enable xbmb3c mode:
settings > skin > General tab: select XBMB3C Addon
now go to your home screen and it should be pulling from your mb3 server. also note, i think i updated my skin for plugin version 0.9.0, which has some new variables/enhancements. it should be pushed to the xbmc repo soon, but you can grab the latest from git if something isnt working in arctic
https://github.com/MediaBrowser/MediaBrowser.XBMC
edit:
saitoh183
there are some good usability updates coming that will help that.
(2014-04-21, 19:59)el_cabong Wrote: [ -> ]edit:
@saitoh183
Thanks and does the GIT version contain these updates?
(2014-04-21, 21:20)saitoh183 Wrote: [ -> ] (2014-04-21, 19:59)el_cabong Wrote: [ -> ]edit:
@saitoh183
Your request for favorite shows as just been added to the git version!
I'm having issues setting this plugin up. I have put all the info in but i'm getting URL: Unauthorized Error. The log says the following is being added to the URL "/Users?format=json" And i think that is causing the error. Anyway to remove this?
Turns out the issue with the MB3 Server I was using.. Problem solved.
(2014-10-28, 03:36)bxsteez Wrote: [ -> ]I'm having issues setting this plugin up. I have put all the info in but i'm getting URL: Unauthorized Error. The log says the following is being added to the URL "/Users?format=json" And i think that is causing the error. Anyway to remove this?
No - that is correct syntax. What version of AddOn, XBMC and MB3 server are you using?
It would be better to continue this conversation at the MediaBrowser forum as most users are over there now.
I will need a log file, but please post over there.
http://mediabrowser.tv/community/index.p...99-xbmb3c/
xnappo
[EDIT] I see you already posted there - so nevermind
Hi, love the media browser addon. But noticed that with tv highlighted it doesn't show recently added like with movies.
(2015-05-05, 17:26)cpt_hooker Wrote: [ -> ]Hi, love the media browser addon. But noticed that with tv highlighted it doesn't show recently added like with movies.
You should check out there new plugin that integrates with kodi database.It makes MySQL useless and has many more benefits. For support check out
Link
