2014-01-08, 10:46
2014-01-08, 18:23
Not to be annoying, but we really, really need logs to be able to tell anything.
xnappo
xnappo
2014-01-08, 18:45
When I ftp into my PI there are no directories or files I can use the filemanager to get the profile stuff from the addon directory, but I can't get to the xbmc.log, as it is in a hidden directory. I will try to ssh into the PI when I get home. Is there an easier way to get the logs via a plug in? My PI is 2 stories away from my computer, so there is a lot of up the stairs down the stairs going on.
2014-01-08, 18:51
(2014-01-08, 18:45)w84no1 Wrote: [ -> ]When I ftp into my PI there are no directories or files I can use the filemanager to get the profile stuff from the addon directory, but I can't get to the xbmc.log, as it is in a hidden directory. I will try to ssh into the PI when I get home. Is there an easier way to get the logs via a plug in? My PI is 2 stories away from my computer, so there is a lot of up the stairs down the stairs going on.
Even if you can't see it, you might be able to manually browse into it. '.xbmc'.
[EDIT] Easy log files:
http://wiki.xbmc.org/index.php?title=Log_file/Easy
But ALSO remember to turn on the AddOn Debug log too in step 2.
xnappo
2014-01-08, 19:17
i'll get you a log tonight when i'm using the correct version and not in the pub. not annoying at all!
2014-01-08, 19:57
I will post my logs also. Thanks for the log addon link, very handy!
2014-01-09, 00:23
i get the same script error when trying to load the movies collection containing 750 folder and roughly 1050 movies. bunch of files retrieved from the pi here https://dl.dropboxusercontent.com/u/3954...483958.zip.
i never actually get to see the collection contents
2014-01-09, 00:37
(2014-01-09, 00:23)spaceboy Wrote: [ -> ]i get the same script error when trying to load the movies collection containing 750 folder and roughly 1050 movies. bunch of files retrieved from the pi here https://dl.dropboxusercontent.com/u/3954...483958.zip.
Need the xbmc.log file..
xnappo
P.S. null_pointer just posted a fix for one issue about 15 minutes ago.. Dual discussions going on here and here:
http://mediabrowser3.com/community/index...mc/page-14
2014-01-09, 01:00
xbmc.log. https://dl.dropboxusercontent.com/u/39548367/xbmc.log should i try null_pointers latest master?
ok i'm coming over to mb3 forum
2014-01-09, 04:17
yeah sorry, a bit of cross posting going on here.
The errors are due a few places data being treated differently between xml json parsing, xml gives None and json gives "" etc
I am trying to get all these sorted out now. Please try the latest and see how you go.
2014-01-09, 05:35
Tried the latest and I get a script error when I try to enter into a collection.
http://xbmclogs.com/show.php?id=107963
2014-01-09, 06:09
Are you positive that you have the latest default.py? That is the exact error Null_Pointer fixed earlier today..
xnappo
xnappo
2014-01-09, 14:46
I uninstalled the addon, deleted the xbmc addon directory, then downloaded from the master branch of null_pointer's repo. Is there something I am missing?
2014-01-09, 16:49
Someone else on the MB3 forum is also reporting that error is still happening for them - please get the latest default.py - which has additional debug prints - and try again please.
Hopefully this will all be worth it in the end!
While I do intend to respond to both threads - if we could move the Pi discussion over the the MB3 board, it would be helpful...
Thanks,
xnappo
Thanks,
xnappo
2014-01-09, 18:58
OK, I will post my logs there after I get home.
thanks to everyone for all the effort!
