2013-11-17, 12:56
I have a remote IR reciever through my serial port. I installed WinLirc on my Windows 8 machine and setup a remote.conf file. When I press a specific button, WinLirc icon turn green, so WinLirc sees my IR signal.
Then I setup a lircmap.xml in the C:\Users\<account>\AppData\Roaming\XBMC\userdata folder with the correct remote name and commands. After that I setup a keymap.xml file in C:\Users\<account>\AppData\Roaming\XBMC\userdata\kemaps\ folder with the correct commands that I setup in the lircmap.xml.... Then I start XBMC to see that this setup doesn't work... XBMC doesn't responds on my remote.... It is very hard to find any information on the web... What do I do wrong or what is missing?
