2015-12-18, 03:49
2015-12-18, 11:05
Same problem here.
09:58:14 T:6028 NOTICE: -->Python Interpreter Initialized<--
09:58:15 T:6028 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "L:\Users\Uta\AppData\Roaming\Kodi\addons\plugin.video.vevo_tv\default.py", line 532, in <module>
customMain(url)
File "L:\Users\Uta\AppData\Roaming\Kodi\addons\plugin.video.vevo_tv\default.py", line 107, in customMain
data=re.findall('browseCategoryList(.*?)]',content,re.S)[0]
IndexError: list index out of range
09:58:15 T:9144 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.vevo_tv/?mode=customMain&shuffled=false&url=default
09:58:15 T:9144 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vevo_tv/?mode=customMain&shuffled=false&url=default) failed
09:58:15 T:5716 NOTICE: Thread LanguageInvoker start, auto delete: false
2015-12-19, 17:56
Yes, same problem here with VEVO TV. I sure hope there will be a fix for this as my wife and I routinely watch VEVO TV in the custom mode.
2016-01-01, 20:30
Custom category in VEVO TV still not working. Too bad, this make a perfect "party" setting for music videos.
2016-01-02, 00:19
Is there going to be a fix for this?
2016-01-17, 19:21
Vevo TV custom category is working again. Vevo must have been at fault. Great to have it back!
2016-04-13, 09:37
Hi, is the plugin still working for you? A few things a working for me but
in the category custom I can't start the playlist. Skipping vdos is also not
longer possible at all. Does anybody have a bugfix or a solution therefore?
Br, Mike
Log_output:
Br, Mike
Log_output:
Quote:09:32:54 T:7828 NOTICE: -->Python Interpreter Initialized<--
09:32:55 T:4348 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.vevo_tv/?url=SEBGV1500015&mode=playVideo]
09:32:59 T:4348 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.vevo_tv/?mode=playCustom&shuffled=true&url=http%3a%2f%2fapi.vevo.com%2fmobile%2fv1%2fvideo%2flist.json%3forder%3dMostViewedToday%26offset%3d0%26max%3d200
09:32:59 T:4348 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.vevo_tv/?mode=playCustom&shuffled=true&url=http%3a%2f%2fapi.vevo.com%2fmobile%2fv1%2fvideo%2flist.json%3forder%3dMostViewedToday%26offset%3d0%26max%3d200) failed
09:32:59 T:7572 NOTICE: Thread LanguageInvoker start, auto delete: false
2016-04-29, 20:43
Keeps on saying not available in your country. I am in USA. Does it not work here anymore?
2016-05-18, 05:15
(2016-04-29, 20:43)hindibuff Wrote: [ -> ]Keeps on saying not available in your country. I am in USA. Does it not work here anymore?
Same issue here. It has been like this for awhile. Is this version no longer being updated?
Thank you
2017-02-17, 22:58
Is this add-on dead?
