Full Version: 720P 60FPS?
Hi Guys,
I'm just getting starting with PVR (HDHomeRun Prime + WMC PVR) and I have a question about frame rates.
The first recording I tested was of Almost Human and the broadcast was 720P at 60FPS.
When converting -- using Handbrake or WMCBuddy -- should I output at 60FPS?
It looks like most digital files, including iTunes releases of this show, are 24FPS.
Is it possible/optimcal, to convert to 24FPS, or should I stick with 60?
The picture looks ever so slightly "fuzzy" when I shrink it using Handbrake/MCEBuddy around 4,000kbs bitrate.
Thanks,
Owen
Or, do I need to change a.setting to record at 24fps?
So to answer my own question... I'm not sure if it's right or wrong, but I managed to accomplish this using Handbrake.
I used RF19 and set the framerate to 23.976 and it looks great on my TV.
Nothing is broadcast at 60fps AFAIK.
Why are you transcoding?
I'm out of practice, but I think technically US HD 1080i and 720i are broadcast at 60 fields per second. Not quite the same thing, but when recording, WMC PVR spits out a 60fps file.
