Full Version: [RELEASE] NetfliXBMC - Unofficial Netflix Add-on (Win/OSX/Linux)
Hello ADSE,
Thanks a lot for an excellent plugin! Also looking forward to any Amazon version later on. Keep up the good work, because it's most appreciated!
a small suggestion/request for your next update:
Could you add a custom library folder? I have my HDD partitioned according to different uses, and it would be most useful to be able to place the netflix library additions in a separate folder/disk from the userdata, and along with the rest of my actual movie files.
Thanks again Smile
(2014-03-01, 03:27)AddonScriptorDE Wrote: [ -> ]Hey,
first - sorry for the late reply. I'm just too busy last weeks.
Netflix changed some small thing on login, so the addon wasn't working for new users.
To fix this, change line 473 of default.py to:
content = opener.open("http://movies.netflix.com/Login").read()
I'll try to answer/solve the other questions/problems (and release an update) next week...
Greetings,
asde
Awesome, wish I'd seen this earlier, works fine with the updated login URL Smile
Is there anyway to just browse latest movie and latest tv shows separate? Instead they are all mixed up under latest
I followed all of the directions at http://lifehacker.com/netflixbmc-brings-...1484237283 to get Netflix working in XBMC.
I get a script error when choosing my category.
Here is the log file...it is long so sorry about that.
11:36:27 T:2692  NOTICE: -----------------------------------------------------------------------
11:36:27 T:2692  NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Windows 8 64-bit, build 9200. Built on Dec 19 2013 (compiler 1600)
11:36:27 T:2692  NOTICE: Intel(R) Core(TM)2 Duo CPU     P8600  @ 2.40GHz
11:36:27 T:2692  NOTICE: Desktop Resolution: 1440x900 32Bit at 60Hz
11:36:27 T:2692  NOTICE: Running with restricted rights
11:36:27 T:2692  NOTICE: Aero is enabled
11:36:27 T:2692  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
11:36:27 T:2692  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
11:36:27 T:2692  NOTICE: special://masterprofile/ is mapped to: C:\Users\Mark\AppData\Roaming\XBMC\userdata
11:36:27 T:2692  NOTICE: special://home/ is mapped to: C:\Users\Mark\AppData\Roaming\XBMC\
11:36:27 T:2692  NOTICE: special://temp/ is mapped to: C:\Users\Mark\AppData\Roaming\XBMC\cache
11:36:27 T:2692  NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
11:36:27 T:2692  NOTICE: Local hostname: Mark-Laptop
11:36:27 T:2692  NOTICE: Log File is located: C:\Users\Mark\AppData\Roaming\XBMC\xbmc.log
11:36:27 T:2692  NOTICE: Found 2 Lists of Devices
11:36:27 T:2692  NOTICE: Enumerated DirectSound devices:
11:36:27 T:2692  NOTICE:     Device 1
11:36:27 T:2692  NOTICE:         m_deviceName      : {4150DCEA-7425-498A-BC38-8A58B2AB3570}
11:36:27 T:2692  NOTICE:         m_displayName     : Speakers - Speakers (Conexant 20561 SmartAudio HD)
11:36:27 T:2692  NOTICE:         m_displayNameExtra: DirectSound: Speakers (Conexant 20561 SmartAudio HD)
11:36:27 T:2692  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
11:36:27 T:2692  NOTICE:         m_channels        : FL,FR
11:36:27 T:2692  NOTICE:         m_sampleRates     : 44100
11:36:27 T:2692  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3
11:36:27 T:2692  NOTICE:     Device 2
11:36:27 T:2692  NOTICE:         m_deviceName      : {1FFE90BE-E95A-412F-9D04-C01F4708FE76}
11:36:27 T:2692  NOTICE:         m_displayName     : SPDIF - SPDIF Interface (Conexant 20561 SmartAudio HD)
11:36:27 T:2692  NOTICE:         m_displayNameExtra: DirectSound: SPDIF Interface (Conexant 20561 SmartAudio HD)
11:36:27 T:2692  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
11:36:27 T:2692  NOTICE: Enumerated WASAPI devices:
11:36:27 T:2692  NOTICE:         m_displayNameExtra: WASAPI: SPDIF Interface (Conexant 20561 SmartAudio HD)
11:36:27 T:2692  NOTICE:         m_sampleRates     : 96000,48000,44100
11:36:27 T:2692  NOTICE:         m_dataFormats     : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:36:27 T:2692  NOTICE:         m_displayNameExtra: WASAPI: Speakers (Conexant 20561 SmartAudio HD)
11:36:27 T:2692  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
11:36:27 T:2692  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:36:27 T:2692  NOTICE: load settings...
11:36:27 T:2692  NOTICE: special://profile/ is mapped to: special://masterprofile/
11:36:27 T:2692  NOTICE: loading special://masterprofile/guisettings.xml
11:36:27 T:2692  NOTICE: Getting hardware information now...
11:36:27 T:2692  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:36:27 T:2692  NOTICE: Loaded playercorefactory configuration
11:36:27 T:2692  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:36:27 T:2692  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:36:27 T:2692  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:36:27 T:2692  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:36:27 T:2692  NOTICE: Default DVD Player: dvdplayer
11:36:27 T:2692  NOTICE: Default Video Player: dvdplayer
11:36:27 T:2692  NOTICE: Default Audio Player: paplayer
11:36:27 T:2692  NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:36:27 T:2692  NOTICE: Log level changed to 0
11:36:27 T:2692  NOTICE: Loading media sources from special://masterprofile/sources.xml
11:36:27 T:564  NOTICE: Thread CSoftAE start, auto delete: false
11:36:27 T:2692  NOTICE: Running database version Addons15
11:36:27 T:3048  NOTICE: Thread XBMC Peripherals start, auto delete: false
11:36:27 T:5512  NOTICE: Thread CRemoteControl start, auto delete: false
11:36:27 T:4200  NOTICE: Thread XBMC Peripherals start, auto delete: false
11:36:27 T:2692  NOTICE: Found screen: ThinkPad Display 1440x900 on ATI Mobility Radeon HD 3400 Series, adapter 0.
11:36:27 T:2692  NOTICE: Primary mode: 1440x900 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 640x480 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Previous line repeats 2 times.
11:36:27 T:2692  NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 720x480 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 800x480 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 800x480 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 800x600 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1024x600 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1024x600 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1024x768 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1152x864 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1280x768 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1280x800 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1440x900 @ 50.00 - Full Screen
11:36:27 T:2692  NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
11:36:27 T:2692  NOTICE: Checking resolution 16
11:36:28 T:2692  NOTICE: Running database version Addons15
11:36:28 T:2692  NOTICE: Running database version ViewModes4
11:36:28 T:2692  NOTICE: Running database version Textures13
11:36:28 T:2692  NOTICE: Running database version MyMusic32
11:36:28 T:2692  NOTICE: Running database version MyVideos75
11:36:28 T:2692  NOTICE: Running database version TV22
11:36:28 T:2692  NOTICE: Running database version Epg7
11:36:28 T:2692  NOTICE: initializing playlistplayer
11:36:28 T:2692  NOTICE: DONE initializing playlistplayer
11:36:28 T:2692  NOTICE: initialize done
11:36:28 T:2692  NOTICE: Running the application...
11:36:28 T:4424  NOTICE: Thread Jobworker start, auto delete: true
11:36:28 T:2692  NOTICE: ES: Starting event server
11:36:28 T:5740  NOTICE: Thread CEventServer start, auto delete: false
11:36:28 T:5740  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:36:28 T:5740  NOTICE: UDP: Listening on port 9777
11:36:28 T:1752  NOTICE: Thread CTCPServer start, auto delete: false
11:36:28 T:84  NOTICE: Thread CRssReader start, auto delete: false
11:36:32 T:3148  NOTICE: Thread Background Loader start, auto delete: false
11:36:36 T:4648  NOTICE: Previous line repeats 1 times.
11:36:36 T:4648  NOTICE: Thread XBPyThread start, auto delete: false
11:36:36 T:4648  NOTICE: -->Python Interpreter Initialized<--
11:36:42 T:2692   ERROR: Control 3 in window 12000 has been asked to focus, but it can't
11:36:50 T:6420  NOTICE: Thread Background Loader start, auto delete: false
11:36:54 T:5840  NOTICE: Thread XBPyThread start, auto delete: false
11:36:54 T:5840  NOTICE: -->Python Interpreter Initialized<--
11:36:55 T:5840   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.IOError'>
                                            Error Contents: (2, 'No such file or directory', 'C:\\Users\\Mark\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.netflixbmc\\profile')
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 749, in <module>
                                                listGenres(url)
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 226, in listGenres
                                                setProfile()
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 509, in setProfile
                                                fh = open(profileFile, 'r')
                                            IOError: (2, 'No such file or directory', 'C:\\Users\\Mark\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.netflixbmc\\profile')
11:36:55 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=KidsAltGenre
11:36:55 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=KidsAltGenre) failed
11:36:55 T:132  NOTICE: Thread Background Loader start, auto delete: false
11:37:17 T:4760  NOTICE: Previous line repeats 1 times.
11:37:17 T:4760  NOTICE: Thread XBPyThread start, auto delete: false
11:37:18 T:4760  NOTICE: -->Python Interpreter Initialized<--
11:37:20 T:140  NOTICE: Thread XBPyThread start, auto delete: false
11:37:21 T:140  NOTICE: -->Python Interpreter Initialized<--
11:37:22 T:6220  NOTICE: Thread XBPyThread start, auto delete: false
11:37:22 T:6220  NOTICE: -->Python Interpreter Initialized<--
11:37:23 T:6580  NOTICE: Thread XBPyThread start, auto delete: false
11:37:23 T:6580  NOTICE: -->Python Interpreter Initialized<--
11:37:23 T:6796  NOTICE: Thread XBPyThread start, auto delete: false
11:37:24 T:6796  NOTICE: -->Python Interpreter Initialized<--
11:37:28 T:3692  NOTICE: Thread Background Loader start, auto delete: false
11:37:43 T:7048  NOTICE: Previous line repeats 2 times.
11:37:43 T:7048  NOTICE: Thread XBPyThread start, auto delete: false
11:37:43 T:7048  NOTICE: -->Python Interpreter Initialized<--
11:37:50 T:2692   ERROR: Control 3 in window 12000 has been asked to focus, but it can't
11:39:39 T:3916   ERROR: Previous line repeats 1 times.
11:39:39 T:3916  NOTICE: Thread Background Loader start, auto delete: false
11:39:45 T:6176  NOTICE: Thread XBPyThread start, auto delete: false
11:39:45 T:6176  NOTICE: -->Python Interpreter Initialized<--
11:39:45 T:6176   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 735, in <module>
                                                listVideos(url)
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 116, in listVideos
                                                setProfile()
11:39:45 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall
11:39:45 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall) failed
11:39:45 T:5264  NOTICE: Thread Background Loader start, auto delete: false
11:40:08 T:3224  NOTICE: Thread XBPyThread start, auto delete: false
11:40:08 T:3224  NOTICE: -->Python Interpreter Initialized<--
11:40:08 T:3224   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listVideos(url)
                                                setProfile()
11:40:08 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall
11:40:08 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall) failed
11:40:08 T:76  NOTICE: Thread Background Loader start, auto delete: false
11:42:51 T:4356  NOTICE: Previous line repeats 9 times.
11:42:51 T:4356  NOTICE: Thread Jobworker start, auto delete: true
11:42:51 T:6372  NOTICE: Thread Background Loader start, auto delete: false
11:43:05 T:6076  NOTICE: Previous line repeats 3 times.
11:43:05 T:6076  NOTICE: Thread XBPyThread start, auto delete: false
11:43:05 T:6076  NOTICE: -->Python Interpreter Initialized<--
11:43:09 T:2692   ERROR: Control 3 in window 12000 has been asked to focus, but it can't
11:43:14 T:1800   ERROR: Previous line repeats 4 times.
11:43:14 T:1800  NOTICE: Thread Background Loader start, auto delete: false
11:43:15 T:144  NOTICE: Thread XBPyThread start, auto delete: false
11:43:15 T:144  NOTICE: -->Python Interpreter Initialized<--
11:43:18 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=search&thumb&url
11:43:18 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=search&thumb&url) failed
11:43:18 T:2172  NOTICE: Thread Background Loader start, auto delete: false
11:43:20 T:4132  NOTICE: Thread XBPyThread start, auto delete: false
11:43:20 T:4132  NOTICE: -->Python Interpreter Initialized<--
11:43:20 T:4132   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listGenres(url)
                                                setProfile()
11:43:20 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=KidsAltGenre
11:43:20 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=KidsAltGenre) failed
11:43:20 T:6156  NOTICE: Thread Background Loader start, auto delete: false
11:43:22 T:140  NOTICE: Thread XBPyThread start, auto delete: false
11:43:22 T:140  NOTICE: -->Python Interpreter Initialized<--
11:43:23 T:140   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listVideos(url)
                                                setProfile()
11:43:23 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiGenre%3fagid%3d6839%26pn%3d1%26np%3d1%26actionMethod%3djson
11:43:23 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiGenre%3fagid%3d6839%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
11:43:23 T:6864  NOTICE: Thread Background Loader start, auto delete: false
11:43:24 T:6456  NOTICE: Thread XBPyThread start, auto delete: false
11:43:24 T:6456  NOTICE: -->Python Interpreter Initialized<--
11:43:25 T:6456   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listGenres(url)
                                                setProfile()
11:43:25 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=WiGenre
11:43:25 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=WiGenre) failed
11:43:25 T:5204  NOTICE: Thread Background Loader start, auto delete: false
11:43:26 T:2040  NOTICE: Thread XBPyThread start, auto delete: false
11:43:26 T:2040  NOTICE: -->Python Interpreter Initialized<--
11:43:26 T:2040   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listVideos(url)
                                                setProfile()
11:43:26 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiGenre%3fagid%3d83%26pn%3d1%26np%3d1%26actionMethod%3djson
11:43:26 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiGenre%3fagid%3d83%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
11:43:26 T:4880  NOTICE: Thread Background Loader start, auto delete: false
11:43:28 T:5864  NOTICE: Thread XBPyThread start, auto delete: false
11:43:28 T:5864  NOTICE: -->Python Interpreter Initialized<--
11:43:28 T:5864   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listVideos(url)
                                                setProfile()
11:43:28 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiHD%3fdev%3dPC%26pn%3d1%26np%3d1%26actionMethod%3djson
11:43:28 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiHD%3fdev%3dPC%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
11:43:28 T:7048  NOTICE: Thread Background Loader start, auto delete: false
11:43:29 T:3532  NOTICE: Thread XBPyThread start, auto delete: false
11:43:30 T:3532  NOTICE: -->Python Interpreter Initialized<--
11:43:30 T:3532   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listVideos(url)
                                                setProfile()
11:43:30 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiRecentAdditionsGallery%3fnRR%3dreleaseDate%26nRT%3dall%26pn%3d1%26np%3d1%26actionMethod%3djson
11:43:30 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fWiRecentAdditionsGallery%3fnRR%3dreleaseDate%26nRT%3dall%26pn%3d1%26np%3d1%26actionMethod%3djson) failed
11:43:30 T:3976  NOTICE: Thread Background Loader start, auto delete: false
11:43:31 T:52  NOTICE: Thread XBPyThread start, auto delete: false
11:43:31 T:52  NOTICE: -->Python Interpreter Initialized<--
11:43:32 T:52   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 751, in <module>
                                                listViewingActivity()
                                              File "C:\Users\Mark\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 276, in listViewingActivity
                                                setProfile()
11:43:32 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listViewingActivity&thumb&url
11:43:32 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listViewingActivity&thumb&url) failed
11:43:32 T:3876  NOTICE: Thread Background Loader start, auto delete: false
11:43:33 T:4064  NOTICE: Thread XBPyThread start, auto delete: false
11:43:34 T:4064  NOTICE: -->Python Interpreter Initialized<--
11:43:34 T:4064   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listVideos(url)
                                                setProfile()
11:43:34 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall
11:43:34 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listVideos&thumb&url=http%3a%2f%2fmovies.netflix.com%2fMyList%3fleid%3d595%26link%3dseeall) failed
11:43:34 T:2128  NOTICE: Thread Background Loader start, auto delete: false
11:44:24 T:6304  NOTICE: Previous line repeats 9 times.
11:44:24 T:6304  NOTICE: Thread Jobworker start, auto delete: true
11:45:33 T:5088  NOTICE: Previous line repeats 2 times.
11:45:33 T:5088  NOTICE: Thread Background Loader start, auto delete: false
11:45:35 T:5200  NOTICE: Thread XBPyThread start, auto delete: false
11:45:35 T:5200  NOTICE: -->Python Interpreter Initialized<--
11:45:41 T:2692   ERROR: Control 3 in window 12000 has been asked to focus, but it can't
11:45:43 T:2216   ERROR: Previous line repeats 1 times.
11:45:43 T:2216  NOTICE: Thread Background Loader start, auto delete: false
11:45:45 T:2444  NOTICE: Thread XBPyThread start, auto delete: false
11:45:45 T:2444  NOTICE: -->Python Interpreter Initialized<--
11:45:46 T:2444   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                listGenres(url)
                                                setProfile()
11:45:46 T:2692   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=KidsAltGenre
11:45:46 T:2692   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listGenres&thumb&url=KidsAltGenre) failed
11:45:46 T:3244  NOTICE: Thread Background Loader start, auto delete: false
11:45:54 T:2692  NOTICE: Storing total System Uptime
11:45:54 T:2692  NOTICE: Saving settings
11:45:54 T:2692  NOTICE: stop all
11:45:54 T:2692  NOTICE: ES: Stopping event server
11:45:54 T:2692  NOTICE: stopping zeroconf publishing
11:45:55 T:5740  NOTICE: ES: UDP Event server stopped
11:45:55 T:2692  NOTICE: stop sap announcement listener
11:45:55 T:2692  NOTICE: clean cached files!
11:45:55 T:2692  NOTICE: unload skin
11:45:55 T:2692 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-focus.png
11:45:55 T:2692 WARNING: CGUITextureManager::Cleanup: Having to cleanup texture button-nofocus.png
11:45:55 T:2692  NOTICE: stop python
11:45:55 T:2692  NOTICE: stopped
11:45:55 T:2692  NOTICE: destroy
11:45:55 T:2692  NOTICE: closing down remote control service
11:45:55 T:2692  NOTICE: unload sections
11:45:56 T:2692  NOTICE: destroy
11:45:56 T:2692 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:45:56 T:2692 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:45:56 T:2692  NOTICE: closing down remote control service
11:45:56 T:2692  NOTICE: unload sections
11:45:56 T:2692  NOTICE: application stopped...
(2014-03-17, 19:08)Dark Volker Wrote: [ -> ]I followed all of the directions at http://lifehacker.com/netflixbmc-brings-...1484237283 to get Netflix working in XBMC.
                                                listGenres(url)
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                listGenres(url)
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                listGenres(url)
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                setProfile()
                                                listVideos(url)
                                                setProfile()
                                                listGenres(url)
                                                setProfile()
This is EXACTLY my scenario, from using the Lifehacker article and down to the same exact error even, which I detailed on page 30 of this thread. So far, no input from anyone on the matter yet; I'm glad to know its not just me and jacobtf!!
Don't know if this is a NetfliXBMC issue or a Chrome Launcher issue, but we'll try here first...
When I press <num-0> to exit Netflix, the focus transfer back to XBMC, but the Chrome browser is still running in the background. I have to switch to the Chrome window, issue an Alt-F4, then switch back to XBMC. Any ideas?
Win XP (yeah, I know. It was legit free)
XBMC 12.3
Netflix 1.2.5
Chrome Launcher 1.1.1
I am using Gotham 13.1 (I think) in Canada and I have an add-on called Netflixbmc ver. 1.2.5 which loaded and enabled as far as I know correctly but when I open it I just see a black screen with the question at the top of "who's watching" with an X beside it and nothing else happens...am I using the wrong version of XBMC for this add-on or have I configured the whole thing wrong....and/or with the wrong version for using in Canada....
I am trying to watch netflix.com in Canada instead of the canadian version....it is working okay on my computer through my browsers but not with xbmc...I would like to stream it through to my wifi hdtv's in the house as well.....
lots of help is needed ....this is quite daunting
ps..if this helps....OS is windows 8.1
I am running my audio through HDMI on my Windows 8.1 HTPC. If I use any other audio profile besides Direct sound in XBMC I get an error in the Netflix API in Chrome that I have a networking issue.
I see a few others have posted about this problem, does anyone have any suggestions as I would like to use WASAPI as it seems that is the only way for me to get my 5.1 working correctly?
Hi, apologies I'm a noob and have had a read of this and can't see an answer, I'm running frodo on osx mavericks. I have the chrome installer working and my login details are correct. I have the settings configured to select profile and launch into the add on, at that point nothing happens. Chrome doesn't seem to kick in at all, nothing appears asking which profile.
I can then navigate out and see the list menu but when I click something I get the script failed error. I understand this could be fixed with asde's comment about changing the script. However I don't understand where to find this on osx. Please can someone help.
Thanks and apologies if I have missed this earlier
Any chance you can rewrite this with urllib3 to fix the SNI problems that urllib and urllib2 have?
I keep getting a script error when ever i try to play a video. I'm a complete noob so I'm not sure whats wrong.
here are the log files, any help would be greatly appreciated. http://xbmclogs.com/show.php?id=152571
Does anyone know of anyway either in this add-on or the chrome launcher to have chrome launch in a new window and possibly open up on a second monitor. I have xbmc running on my tv from my home desktop pc so launching netflixbmc opens up chrome in a new tab on my desktop monitor rather than on mt tv.
Hi I've been trying to add the Netflixbmc add-on with no luck. It doesn't appear in the AddonScriptorDE's Testing Repo no matter how many times I "Refresh" or "Check for Updates". I know that I've been able to successfully Refresh the repo listing as when I first went into it there weren't many add-ons listed at all. When I Refreshed, I got all of them...except (apparently?) Netflixbmc
Question: I found a zip file for the add-on itself entitled "plugin.video.netflixbc-master.zip". Downloaded it, and tried to force install it with two methods:
- firstly using the Add-ons->Install from zip file function. This returned the error "Add-on does not have the correct file structure".
- then I did some poking around and found these set of instructions: http://www.xbmc4xbox.org.uk/wiki/HOW-TO_...ns_in_XBMC which admittedly are not for a Frodo Android install, true, but they clued me into to using File Manager HD to figure out where all the plugins were installed, so then I took the zip file, unzipped it into a folder named similarly to all the other plugins, and slammed it into that plugin directory.
Still no success. So I guess my questions: has the Netflixbmc Add-on been pulled from the AddonScriptorDE repo? If not, is there maybe another repo I can try to grab it from? Or...since I have the actual Netflixbmc plugin zip (I think)..is there a way I can compare it to make sure the file structure is ok or even manually drop it into my XBMC install?
Thanks for any help. I'm running a G-Box MX-2 with Linux 3.0.50 o/s
Get the Repo - https://code.google.com/p/addonscriptord...loads/list
Download and save
- > 'Addons' - 'install from zip file', select the repo from your saved location and install.
Then, 'Get Add-ons' - click on the 'AddonscriptorDE's testing repo' - scroll down to video add-ons and select that; scroll to NetfliXBMC and install.
They are listed alphabetically - NetfliXBMC will be the first 'N' - after Mediatheken and before Nickelodeon.de
If you already have the repo installed, but don't see the NetfliXBMC add-on listed in the list of Video Add-ons, backspace to the list of all installed repos, right click on the 'AddonscriptorDE's testing repo' in the list and 'force refresh', then check again under video add-ons.
(2014-03-20, 02:49)DEcosse Wrote: [ -> ]^^^
Download and save
These were all the first things I tried. I have Mediatheken and Nickelodeon. No NetfliXBMC. That's what led me to try various "back door methods".
I should add: I installed both this repo from the same link and the NetfliXBMC add-on to my laptop 2 weeks ago and had success the very first time.
There's something really odd about what I'm experiencing here..I merely used the same .zip I downloaded to my laptop, copied it to a USB stick, and accessed that USB stick as external storage on my G-Box to find the .zip and install it. It should have behaved the same way, no?
