2014-10-17, 15:25
I'm running NetfliXBMC 1.3.4 in Gotham 13.2 and no matter what I do I get "You are not logged in. Check your credentials and/or restart the addon!"
(2014-10-18, 19:28)ikkeenjij36 Wrote: [ -> ]After complete fresh install still the same issue.Several users already helped you, but you at least should read/try the suggestions.
Can anyone help me with this?
(2014-10-13, 07:27)xyii Wrote: [ -> ](2014-10-13, 06:02)ikkeenjij36 Wrote: [ -> ]Working fine here on xbmcbuntu. Seems to be also working for others.(2014-10-13, 03:02)JasonPell Wrote: [ -> ]So can you use Netflix directly from chrome on xbmc Ubuntu? I have never used xbmc Ubuntu so don't know if you can load chrome directly. Does xbmc Ubuntu have a window manager?No and no.
it doesn'seem to run on xbmcubuntu.
it will work on ubuntu with xbmc and with this addon.
and there is my problem
want to run xbmcubuntu cause i can control it with my harmony one.
if i run ubuntu and then install xbmc on it i still have to use mouse and/or keyboard.
but if i run it like that the addon will work.
so maybe there is an dev of xbmcubuntu who whants take a look in it.
Maybe you should read the xbmcbuntu install instructions that are linked in the first post.
You just have to install Chrome and config your chrome launcher script (depending on what window manager you are using).
(2014-10-18, 20:01)xyii Wrote: [ -> ]Well netflix plays in xbmcbuntu but i have the problem witn no sound thruogh hdmi on my intell nuc.(2014-10-18, 19:28)ikkeenjij36 Wrote: [ -> ]After complete fresh install still the same issue.Several users already helped you, but you at least should read/try the suggestions.
Have you followed the xbmcbuntu install instructions from post 1? I already mentioned it to you before:
(2014-10-13, 07:27)xyii Wrote: [ -> ](2014-10-13, 06:02)ikkeenjij36 Wrote: [ -> ]No and no.Working fine here on xbmcbuntu. Seems to be also working for others.
The behavior you described (chrome on part of screen) is exactly what you see without a window manager...
(2014-10-20, 01:49)teeedubb Wrote: [ -> ]Mint uses pulseaudio, which allows mixing of streams fr various sources. Xbmcbuntu uses alsa only, which with out additional configuration, doesn't allow mixing of streams. If you want to use multiple sources with alsa you need to configure dmix.
20:14:06 T:356 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.WindowsError'>
Error Contents: [Error 2] The system cannot find the file specified
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc-1.3.4\default.py", line 1007, in <module> configureUtility()
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc-1.3.4\default.py", line 588, in configureUtility
subprocess.Popen('"'+utilityPath+'"'+' config=yes', shell=False)
File "C:\Program Files (x86)\XBMC\system\python\Lib\subprocess.py", line 711, in __init__
errread, errwrite)
File "C:\Program Files (x86)\XBMC\system\python\Lib\subprocess.py", line 948, in _execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file specified
