Hello everyone.
How is XBMC, Apple TV and TV settings be when it comes to sound.
I have a Samsung Smart TV.
How should the settings be on TV and Apple TV and XBMC to get the best sound?
Monty
(2013-11-23, 16:13)montydk Wrote: [ -> ]Hello everyone.
Monty
Defaults will take care of most people, especially if you are only using TV speakers and no special audio system. Anything else depends on the sound equipment that you have.
Ok what is the default audio settings??
... the ones it came with when you install XBMC for the first time. If you didn't change any settings then you're fine.
I have changed it, is there a way i can reset the audio only ??
Nightly builds (wiki) can reset settings from within XBMC. Current stable builds require that you delete the guisettings.xml file from the
userdata folder (wiki).
Before you go and do all of this, is anything actually broken or not working? Very little will change the quality of the sound, so normally it's either working or not working.
