The WMC client does not have a hierarchy if there is only one recording or if the recording is a movies.
Do we want the same? Should it be an option or just always work that way.
Again I would be happy to look at adding this as an enhancement just wanted to get some ideas first.
(2013-11-23, 23:04)spinnaker Wrote: [ -> ]The WMC client does not have a hierarchy if there is only one recording or if the recording is a movies.
I thought about this, but decided that if it detects that its an episode of a series I like it better if it is one level down. But this could be made an option in the future.
So movies will be at main level?
Yeah I am torn on series too. It is a nice way to see both the series and episode name. I think in WMC, if it is only 1 episode, you don't see the episode name till you open it up.
(2013-11-24, 00:07)spinnaker Wrote: [ -> ]So movies will be at main level?
I think you are right about wmc, but I am not necessarily trying to copy everything wmc does. As for movies, if you choose to not group them in a 'movies' folder they should be at the top level not a level down.
