Full Version: How to add a control to the home window programatically?
How do I add a control from the home window
For example:
If I created a label
label = xbmcgui.ControlLabel(100, 250, 125, 75, 'Status', angle=45)
How would I add this control to the home window programaticlly?
I assume I would have to get the home window somehow, then add the new control to it.
Thanks in advance!
(2013-11-24, 05:07)nickthemagicman Wrote: [ -> ]How do I add a control from the home window
For example:
Thanks in advance!
You need to create a xbmcgui.Window instance with a proper ID and then add your control to that instance.
