2013-11-28, 17:35
plugin.video.quake.live: Broken
What it is: http://www.quake-live.tv
QuakeLive, Archived Quake Live Matchs. QuakeLive.tv's goal is to supply everything in one destination--information on upcoming matches, archives of past matches, tons of great video on demand that shows full-length match replays from the lead shoutcaster's perspective, an expansive demo collection, and tons of other great, community-building features.
Features:
Windows, Linux
Download:
This add-on can be found in the official kodi.tv add-on repository.
This add-on can also be downloaded from my Git Repo.
Change log:
Source Code: https://github.com/willforde/plugin.video.quake.live
Note If you get error "Dependencies not met". You may need to install the latest script.module.xbmcutil addon.
Features:
- Links to Youtube Channel. http://www.youtube.com/user/TheQuakeLiveTV
- Support to set Viwemodes for current skin or any custom viewmode under settings. Supports all skins as of 2015-02-20.
- Add-To / View Playlist via Context Menu.
- All HTTP Resources are cached localy for speed improvements, allowing for HTTP 304 not modified support.
- Any HTTP Resource can be forced refreshed via Context Menu.
- Sort by Date or Title.
Windows, Linux
Download:
Change log:
Version 2.0.1 2016-01-04
- Added option to disable url caching from the add-on settings.
- Marked as Broken
Version 2.0.0 2015-02-20
- Removed download support
- Changed to use the YouTube V3 API
- Changed to auto select content type
- Changed to auto select sort methods
- Changed to return a generator instead of a list
- Changed settings.xml to use new methods for setting view mode
- Some small method renames
