Full Version: Streaming Internet Radio!
Hi all
I've tried and tried to get this to work, read so many sites with possible suggestions and think I have tried pretty much everything!
I go to a live radio website which works fine on my PC, select 'view source' on the player page and get this:
http://www.xl103calgary.com/mediaplayer/...t=63404353
Then I copy that URL into a notepad, save the file as an .STRM and try to launch in XBMC. It says 'buffering' for a split sec, then nothing. Any ideas?
Here's the log:
Pastebin Log
Thanks in advance.
Not so easy. The link is only to a website with an embedded flash player that actually does the streaming.
Requires Wireshark to catch the actual stream information and some time and skill to interpret it.
Failing any better advice... you could use something like advanced launcher to launch a browser to the link when you want to play it.
@Latz
Any of these should work:
http://3463.live.streamtheworld.com:80/CFXLFMAAC_SC
http://3463.live.streamtheworld.com:3690/CFXLFMAAC_SC
http://3463.live.streamtheworld.com:443/CFXLFMAAC_SC
These were obtained by simply spoofing the user-agent to be an iphone, clicking on the original link and then opening up the resulting .pls file in a text editor.
Create a strm file with this in it:
#EXTINF: -1,XL 103.1 Calgary's Greatest Hits (Stream 1)
#EXTINF: -1,XL 103.1 Calgary's Greatest Hits (Stream 2)
#EXTINF: -1,XL 103.1 Calgary's Greatest Hits (Stream 3)
Thanks to mayoman and spoyser!!!!
@spoyser... that's an amazing trick I'd have never thought of that!! Thanks for the tip and for the help, I'm going to try to add another one and see how I get on.
@spoyser hmm didn't work for me, I'm using Chrome. Changed the useragent to Iphone 5, navigated to the link but it didn't bring up a .pls?
The site I tried was:
http://player.rogersradio.ca/chfm/recently_played
What I noticed was it seemed to remove the useragent changes, but even when I tried to re-add the useragent it didn't come up with a .pls
Thanks for your help!!
@Latz
Unfortunately it doesn't work for every site, only if the web-site owners have added iPhone/iPad support (in actual fact non-flash support)
You can double check the user-agent change has worked by going here
http://www.zytrax.com/tech/web/browser_id.shtml
This will tell you the user-agent supplied by the browser
Thanks @spoyser, appreciate your help and the explanation :-)
