Full Version: [MOD] Bello Winter
I just downloaded and installed Bello for the first time a couple days ago, I love the look of this skin and was especially wowed by the optional animated menu. It gave me the idea of creating a Winter Themed version, so I messed around for a couple hours and created this mod. The mod contains:
  • Animated drifting snow menu.
  • New default background image.
  • New navigation sounds. (There were none before, so I built a set).
  • Modified menu graphic.
  • Modified color for "unwatched" indicator in list mode. (Changed from white to blue)
Some of the color changes were copied over from the blue theme that someone else created (kudos to whoever made the blue mod). This is my very first time modding a skin, however I am a graphic and web designer so I'm not afraid of Photoshop or code. Anyways, I hope this mod proves as a fun skin to use over the winter season. Happy Holidays everyone! Enjoy.
watch gallery
DOWNLOAD
Bello Winter (Full Skin)
http://bit.ly/192uzaj
Bello Winter (Mod) - Simply copy the folder contents and overwrite in the "skin.bello" folder.
http://bit.ly/1aMrqze
How do you get the different fan art for background to change automatically?
This is great.. thanks for sharing!
Used this mod on a HTPC for my mum and she is utterly delighted. Thanks for sharing it Smile
Hello eQUIV, nice MOD congratz!!
Think you could help us with the LIST view?
Here's the issue --> http://forum.xbmc.org/showthread.php?tid=178755
think u can fix this for us?
as i feel the author wont fix this until official gotham is released :/
thanks!!
(2013-11-28, 16:19)eskro Wrote: [ -> ]Hello eQUIV, nice MOD congratz!!
thanks!!
Thanks. I'm glad so many people like this mod. Over 100+ downloads so far.
I managed to correct the scrolling problem, and updated this Winter mod accordingly. If you don't want to run this version of Bello but want the fix, just download the mod-only zip file, grab all the files in the "720p" folder EXCEPT for "Includes_Home.xml" and overwrite the existing versions in your current Bello folder.
wooaaa thanks eQUIV!! WoW, you rock!!! your the best!! Smile
(2013-11-25, 14:25)Chico0106 Wrote: [ -> ]How do you get the different fan art for background to change automatically?
I know it has to do with the multi image but what folder do I use or do I create one if I have to create one where do I get the images at?
You have to create a folder. If you want some great wallpapers you can get them at http://www.themoviedb.org
Or if you're looking for some nice packs, there are some right here on the XBMC "Artwork Packs" sub forum.
http://forum.xbmc.org/forumdisplay.php?fid=71
If enough people are interested, I suppose I could build some packs based on the images I use in my videos.
i have a problem for some reason i cant change the view of my tv shows i enable them but when i click it nothing happens i can change the viewtype option but doesnt change the layout just the fan art and cover art
other than that decent skin
never mind i got it
(2013-12-21, 13:28)richs09 Wrote: [ -> ]i have a problem for some reason i cant change the view of my tv shows i enable them but when i click it nothing happens i can change the viewtype option but doesnt change the layout just the fan art and cover art
never mind i got it
Can you say what you did?! I hate when people don't put the solution!
