iv just had to come back to this skin cause everything works perfect for me with this skin
but the view types in MQ5 are better IMO in the coverflow view theres no black bar going across the bottom of the screen
wish there was a way to turn that off in NOX or is there a way to add in these custom view types??
If you mean the info bar that has the pg rating and etc, then no. You'd have to fiddle with the xmls.
Hey robert.... if you can be more specific as to which View (Showcase, Shift, InfoWall, etc)... and which black bar, I can take a stab at editing the xml file or telling you which limes to edit....
hi
yeah its the black bar running across the bottom of screen in this pic i got from another persons thread
http://i.imgur.com/gU56ikG.jpg
if that black bar could be removed and the covers be more at the bottom of screen in coverflow view that would be cool imo the way it is it covers up so much of the fanart i dont use the pannels like that pic above
not a big issue i know lol im just weird like that i supose lol
Also, the osd info screen when playing a movie or tv show looks great! The screen in Nox looks cool as wel, but i like to see the plot without pausing the video for example...
(2013-11-26, 04:52)robert1901 Wrote: [ -> ]hi
If you remove that blackbar, to see more fanart, then the Coverflow will not feel like a coverflow... coverflow needs a floor. If its fanart that you want to emphasize, go for another view that shows fanart better.
But I am still trying to figure out the XML and see if it can be disabled via code...
If you go to the /media/views/ folder, move all the files that start with "showcase" to another folder... You still have the white glow accent... but I cannot figure out what file this is... You need to be using the Github version of the plugin... where the /media folder contains all the images usd by the skin...
https://github.com/BigNoid/Aeon-Nox/tree/master/media
