Full Version: How to display 'Time remaining' in the PAUSED dialog in Confluence
I previously posted How to display 'Time remaining' in the OSD dialog in Confluence . For consistency, I also wanted to modify the PAUSED dialog to do the same. Here is how I did it.
I modified the file DialogSeekBar.xml in the application's folder :
/Applications/XBMC.app/Contents/Resources/XBMC/addons/skin.confluence/720p/DialogSeekBar.xml
Copy and paste the file so you have a backup.
Open DialogSeekBar.xml in a text editor.
Search for the line:
<label>$INFO[Player.Time] - $INFO[Player.Duration]</label>
in the code block
            <control type="label">
                <description>Elapsed Time Label</description>
                <posx>20</posx>
                <posy>23</posy>
                <width>240</width>
                <height>20</height>
                <font>font13_title</font>
                <textcolor>white</textcolor>
                <align>left</align>
                <aligny>center</aligny>
                <visible>!Player.Seeking</visible>
            </control>
Comment it out:
<!-- <label>$INFO[Player.Time] - $INFO[Player.Duration]</label> -->
Add this line after it:
<label>$INFO[Player.Time] (-$INFO[Player.TimeRemaining(hh:mm:ss)])</label>
Save the file and replace the original file with the modified version. Now the PAUSED dialog displays time remaining:
Many thanks for sharing this one as well, just what I was looking for.
Just found this as its what I am looking for but will it work with another skin or just Confluence only ? I want to use it with Aeon Nox Silvo but its DialogSeekBar contents are very different ? I have asked over there but not getting any help with it so thought I might try my luck here if anyone might know ?
Thanks anyway.
(2015-08-30, 14:36)timoxx4 Wrote: [ -> ]Just found this as its what I am looking for but will it work with another skin or just Confluence only ? I want to use it with Aeon Nox Silvo but its DialogSeekBar contents are very different ? I have asked over there but not getting any help with it so thought I might try my luck here if anyone might know ?
The concept is probably the same, but the actual XML used to generate the DialogSeekBar could be very different between skins. So you probably can't just copy a file from Confluence over to Aeon Nox.
Thanks anyway.
Yeah... no help at all...
I just spent hours adding things and helping you problem solve... but whatever Sad
Impatience seems to be an epidemic...
Sorry Mike.Sad I feel really bad now. I wrote that some time ago before I realised what you had indeed done in my confusion eairler and forgot all about it. Really very very sorry again. My bad.
Hi, I just made this change in Confluence for Kodi 15.2
In DialogSeekBar.xml
find
make a copy and comment it
replace the original line
with
<label>at $INFO[Player.Time], $INFO[Player.TimeRemaining(hh:mm:ss)] left</label>
There are 2 instances
Hope this helps
