I'm not really sure if this is a Aeon issue or a xbmc issue but thought I would start here first. I name my trailers as moviename-trailer.ext but when I update my library I get 2 copies of the movie, one of which is the trailer. I've been working around this issue by placing my trailers with my extras and if I want to watch them I just go to the "Extras" menu but I would really like to get them working properly. Anyone have any ideas?
wgstarks, create advancedsettings.xml file and use this code for exclude trailers items from collection
<video>
<excludefromscan>
<regexp>-extras-</regexp>
<regexp>/Extras/</regexp>
<regexp>Extras</regexp>
<regexp>/extras/</regexp>
<regexp>extras</regexp>
<regexp>-trailer</regexp>
<regexp>[\\/]Extras[\\/]</regexp>
<regexp>[\\/]extras[\\/]</regexp>
</excludefromscan>
<excludetvshowsfromscan>
</excludetvshowsfromscan>
</video>
Outstanding. Thanks. Figured I was missing something obvious. Appreciate you including the code for the Extras too.
(2013-11-27, 03:54)Wanilton Wrote: [ -> ]@wgstarks, create advancedsettings.xml file and use this code for exclude trailers items from collection
<video>
<excludefromscan>
</excludefromscan>
</video>
Hey with some tweaking could I make that stop finding "SAMPLE" files as well?
(2013-11-28, 12:21)AbRASiON Wrote: [ -> ]Hey with some tweaking could I make that stop finding "SAMPLE" files as well?
Yes. Any file names should be able to be excluded as long as the expressions are set correctly in the code. I believe this is case sensitive so you will need to include all variations.
hi
your write <video> ... </video>
shouldn't it be <videolibrary> ... </videolibrary> ?
You could test this with <videolibrary> I guess. I can confirm though that <video> works.
