Thanks for the skin! It is very light and works great with gotham nightlies.
Could I request a potential feature add?
It would be nice to see the forecast of the weather as a shelf item under the weather section. Would this be possible down the road?
The label 'Update Library' on side menu remains as 'Stop Scanning' even if updating is finished.
(2013-11-26, 10:11)piodio Wrote: [ -> ]The label 'Update Library' on side menu remains as 'Stop Scanning' even if updating is finished.
Can you test with Confluence?
There's one thing. I have to hide library progress manually when you enter video playback because XBMC does not do it. Weird thing is when you start scanning, enter video playback and stop it before library update finishes, library progress does not re-appear as it should. In another words, library is still updating but you do not see progress dialog. I'm absolutely clueless why this happens.
(2013-11-26, 12:40)pecinko Wrote: [ -> ] (2013-11-26, 10:11)piodio Wrote: [ -> ]The label 'Update Library' on side menu remains as 'Stop Scanning' even if updating is finished.
Yes, with Confluence, label returns to 'Update Library' normally when updating is finished.
At Amber, the label just toggle between 'Update..' and 'Stop..' wheneverI click the menu.
They don't come back to initial label automatically when updating is finished.
I've seen a bug with the Video Settings menu from playing a video. The Menu falls off the screen and the last option is cut off but still semi visible.
(2013-11-26, 23:07)pyrodex Wrote: [ -> ]I've seen a bug with the Video Settings menu from playing a video. The Menu falls off the screen and the last option is cut off but still semi visible.
Please switch to confluence and tell me how many items are there. I have about 8 or so on Mac so I don't run into this issue and thus can't test properly.
When I download the master.zip file from your Github the change log says that it is version 1.5.0. How do I get 1.5.1?
Should this update be applied to Frodo or just Gotham builds?
(2013-11-27, 01:56)pecinko Wrote: [ -> ] (2013-11-27, 00:10)pyrodex Wrote: [ -> ]Amber has 16 and Confluence has 16 also but confluence seems to have a scrolling function to it. If I go to the bottom in Amber, which the last option is Video Calibration, it attempts to scroll but doesn't.
Try 1.5.1 from Git
Fixed and confirmed. Thanks!
Any word on my larger long term request of a potential weather shelf widget for quick weather information?
(2013-11-27, 01:56)pecinko Wrote: [ -> ]Fixed on Git (1.5.1)
Thank you, pecinko.
Update library label works well. Busy video osd is looks fine now, too.
Regards,
(2013-11-27, 03:34)Scott00007 Wrote: [ -> ]When I download the master.zip file from your Github the change log says that it is version 1.5.0. How do I get 1.5.1?
When you look at a skin via add-ons browser or when you try to switch skins it will show you skin version.
Changelog is updated when release to XBMC repository is being prepared. I don't have time to do it after each commit to Git. See here for more info
https://github.com/pecinko/skin.amber/commits/master
I have split the thread to Gotham and Frodo to make it more obvious what we are talking about
Thanks for heads up.
Thank for splitting things up that does make it much easier to navigate. Obviously I am no expert here but when I downloaded the Frodo zip it shows v1.1 in the change log and since I was recently updated to 1.2.5 I'm a little confused.
To make it easier for you to answer I will try to boil it down.
Will I be prompted if I am attempting to install an older version that the one I currently have running?
If I try to install the build meant for Gotham will I be allowed to or will I be prompted? Is there a bad side to this?
(2013-11-27, 11:34)Scott00007 Wrote: [ -> ]Will I be prompted if I am attempting to install an older version that the one I currently have running?
a) not sure
b) you should not be able to install Gotham version on XBMC Frodo. You can force it manually (copy-paste) but it will brake your skin.
version 1.5.2 (on Git)
update strings and bump add-on version
Add partial watch mark for shelf in progress
Add option to select movie entry from favourites
(2013-12-03, 16:54)pecinko Wrote: [ -> ]Add partial watch mark for shelf in progress
Thank you for update! I like this feature.
But I found a small problem.
I turned on two options at Skin Widget settings: Recommended On, Random Items On, Recently Items Off.
Then the partial watch flag shows on every items on the Shelf like below.
In this case the first three items are 'In Progress' items. But the last three items are 'Random' items, obviously not watched and not partially played.
Could you please look into them?
Many thanks.
(2013-12-04, 08:15)piodio Wrote: [ -> ] (2013-12-03, 16:54)pecinko Wrote: [ -> ]Add partial watch mark for shelf in progress
Thanks for reporting. I had a feeling this was going too easy
