Full Version: ¿How to play original Bluray discs from XBMC in Linux?
Hi all,
I've a HTPC with kubuntu and XBMC and I play with no problems MKVs and ISOs from my own blurays (created with Windows in other computer)
Now I have install a Bluray reader with the aim of playing my blurays directly, and I've found it doesn't work (The ISO file works, but original disc doesn't).
¿Hoy can I enable the play of those original optical disks? I've try installing an addon called "makeMKV" but when I try to use it gives a message saying something like "MakeMKV doesn't work, it is installed?"
¿Can someone lend me a hand? I would like to play original BDs in the easyest possible way, as I play ISOS now.
Many thanks in advance
(2013-11-27, 13:59)teeedubb Wrote: [ -> ]http://forum.xbmc.org/showthread.php?tid=173474
Many thanks for the answer,
I Finally get was I was looking for using makeMKV, the issue was that when I installed prior day it was on the night after 14 hours working and my mind shouldn't be lucid, I had installed XBMC add-on but not the makeMKV itself.
I tested a pair of original blurays I own and seem't to work
Many thanks again
