Full Version: Will Xeebo be updated to work with Gotham?
When Gotham comes out will this skin be updated to work with it? It would be a shame to lose this skin. By far the best of any of the skins I've found.
Well at the moment as far as I understand it Gotham is backwards compatible, so no changes would be needed.
The original developer of the skin, Hitcher, has retired so someone else will need to step up to do the work if it is needed.
(2013-11-29, 00:09)Thev00d00 Wrote: [ -> ]Well at the moment as far as I understand it Gotham is backwards compatible, so no changes would be needed.
The original developer of the skin, freezy, has retired so someone else will need to step up to do the work if it is needed.
Not it's not backward compatible, some things will not work anymore.
Don't know where you read it was
(2013-11-29, 00:11)Martijn Wrote: [ -> ]
So in that case, no, it is going to break. That is such a shame.
