Full Version: media flags
hi all i am trying to change my media icons [IE]...1080... 720 ...rating /sound...for some custom ones i have
but seem to be having problems when i go to the media folder thers just a .xbt file which i can't open
in mq4 i could just change the .png this not the case in mq5..if anyone could give me the idiots guide on how to do this
that would be great....many thanks daz
You will need to unpack the textures.xbt, make your changes and repack.
This will point you in the right direction.
job done thanks samu-rai.....it took a little working out but finaly got there thanks again...daz
No worries. Thanks for the rep.
No need to repack images in media folder.You can use all separate in this folder as it pack in .xbt for live change(but need to reload skin).
