Hello,
I wanted to migrate my strings.xml to new *.po format using this tool:
https://github.com/alanwww1/xbmc-xml2po
I self compiled the sources on Ubuntu 13.10 (saucy) amd64
This is the error I got in runtime:
./xbmc-xml2po -s ../xbmcNordishAddons/service.script.call-notifications
XBMC-XML2PO v0.96 by Team XBMC
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct null not valid
[1] 6486 abort ./xbmc-xml2po -s ../xbmcNordishAddons/service.script.call-notifications
Any help?
Thanks in advance, Nordish
Same error here. Same setup.
Interestingly, I tried a version I compiled back in march that was working then on a different Ubuntu version and get the same error.
Just got it to work.
The README says:
The source directory for addons should be where the addon.xml file exists
For core language file, use the main xbmc source tree as a directory
But I tried {addonpath}/resources/language and it worked.
Hey ruuk,
yes that works! Thanks for the pointer.
So the docs are wrong and the program should check for file existence before opening a file handle on that (wrong) folder..
Anyone is able to fix this? I already filed a issue on github:
https://github.com/alanwww1/xbmc-xml2po/issues/2
It worked also for me until I reboot !?
Is it still working for you guys ?
Wrong Arguments given !
Usage: xbmc-xml2po -s <sourcedirectoryname>
parameter -s <name> for source root directory
The source directory for addons should be where the addon.xml file existsFor core language file, use the main xbmc source tree as a directory
I checked my path using cd command, and it is good.
>> xbmc-xml2po ~/.xbmc/addons/[my plugin]/resources/language
I also tried bellow with no luck.
I did re-make the bin file but same error.
What am I missing ?
Ubuntu 12.04 64 bits Frodo
I found it.
I cancelled the file name validation in main() function of the application in xbmc-xml2po.cpp file, and I added the pSourceDirectory = argv[1] after the cancelled block.
I have an underscore in the name of my plugin (dev version), its probably why it didn't pass the validation, but I still don't understand why it did work initially !?
// Basic syntax checking for "-x name" format
/*while ((argc > 2) && (argv[1][0] == '-') && (argv[1][1] != '\x00') && (argv[1][2] == '\x00') &&
(argv[2][0] != '\x00') && (argv[2][0] != '-'))
switch (argv[1][1])
case 's':
--argc; ++argv;
pSourceDirectory = argv[1];
break;
++argv; --argc;
if (pSourceDirectory == NULL)
printf("\nWrong Arguments given !\n");
PrintUsage();
return 1;
