Full Version: Eden XBMC Adult 18+ Add-on Repository
If you had the current stable repo enabled DISABLE it before you install this
https://github.com/xbmc-adult/xbmc-adult...-1.0.1.zip
Addons will update and fix themselves eventually.
Why Huh :
XBMC Gotham deprecates python api version 1.0 so we had to bump the revision to 2.1.0 otherwise the addons would have been broken on Gotham. Unfortunately this breaks the addons for Eden users so we created a new repo for Eden users.
If you upgrade from Eden remove this repo and install the current stable version.
Thanks Dquaid.
Can you tell me how to install the adult channels on XBMC
(2013-12-15, 01:40)justincrews Wrote: [ -> ]Can you tell me how to install the adult channels on XBMC
http://wiki.xbmc.org/index.php?title=Add...a_ZIP_file
