Full Version: Where is my Power OFF Button??? Android Remote
Hello,
i use the offical android remote. Everything works fine, I can wake up my HTPC by pressing the Power ON button.
My problem is, that I can not Power the HTPC off cause I have no Power Off Button.......where can I find it?
When the remote is connected I only have:
Music
Movies
TV Shows
Pictures
Now Playing
Use as Remote
Can anyone help me?
Use as Remote Control > Power
Is there android remote app that allow me to enter code?
I know the code for my tv but and I have galaxy s4 , but I want an app that allows me to enter the code myself because I can't find it in the lists.
_____________________________
Android Application Development
Artrafael,you rightly say,its so simple you use this Use as Remote Control > Power
celeritas-solutions.com
While the remote control is in vertical mode is the power button the Top button that's unlabelled?
When I rotate my phone and the remote goes into horizontal mode I'm able to see a 'power off' button in the bottom-right hand corner.
The power off works in horizontal mode, but not while the phone is vertical.
If it's in vertical mode and I push the top button I get a xbmc popup message saying that the remote was disconnected, but the system stays powered on.
