fritsch - thanks for replying. I'm afraid that I can't quite grasp what you're telling me, or perhaps I have not explained the issue properly in the first place.
The click from the AVR is just a relay switching on/off the extra channels when it detects a change from two channel stereo to multichannel PCM. But the point I'm trying to make is that PAPlayer, if it is playing six channel 88.2kHz PCM audio, should continue this (even as silent data) when you tell it (
using the remote) to skip to the next track on the album. Obviously if the next track you skip to is in a different format or sampling rate, then I would expect some interruption to the audio stream, but this problem is happening even when there is no change to the source data format. It's a real nuisance and not what I would expect by design. Here's a snip of a log (hope it's not too big as embedded data!) where I let xbmc play three tracks from an album without touching the remote. PAPlayer seems to handle the transition from one track to another without any re-initialisation of the sink and there is no interruption of the audio. If you look at the log at 15:14:06 you will see it hits EOF of the first track, then it seems to have 25 seconds of buffer and switches to track 2. Then at 15:18:35 it hits EOF on track 2, then has 25 seconds of buffer and switches to track 3. All sounds perfect and no switching of format etc. Contrast that with my previous log where the sink is re-initialised to 44.1kHz stereo every time I use the remote to skip to a different track. I can't think this is a design feature? I appreciate your time on this and can see that you are debating with FernetMenta on github, but I'm not a programmer (at least not since 1978 when I used to program in COBOL) so I can't immediately understand what you're getting at. I will have a more detailed look at the code, but I think PAPlayer is already handling normal track transitions ok (perhaps because of some flag setting which inhibits sink re-initialisation), but is not handling forced track transitions.
15:08:48 T:140322940094208 DEBUG: CActiveAE::OpenSink - trying to open device ALSA:hdmi:CARD=NVidia,DEV=1
15:08:48 T:140322940094208 INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=NVidia,DEV=1"
15:08:48 T:140322940094208 INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=NVidia,DEV=1,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x08"
15:08:48 T:140322940094208 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
15:08:48 T:140322940094208 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
15:08:48 T:140322940094208 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 680, bufferSize 2720
15:08:48 T:140322940094208 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 544, bufferSize 2720
15:08:48 T:140322940094208 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 31 ms
15:08:48 T:140322940094208 DEBUG: CActiveAE::OpenSink - ALSA Initialized:
15:08:48 T:140322940094208 DEBUG: Output Device : HDA NVidia
15:08:48 T:140322940094208 DEBUG: Sample Rate : 88200
15:08:48 T:140322940094208 DEBUG: Sample Format : AE_FMT_S32NE
15:08:48 T:140322940094208 DEBUG: Channel Count : 6
15:08:48 T:140322940094208 DEBUG: Channel Layout: FL,FR,BL,BR,FC,LFE
15:08:48 T:140322940094208 DEBUG: Frames : 544
15:08:48 T:140322940094208 DEBUG: Frame Samples : 3264
15:08:48 T:140322940094208 DEBUG: Frame Size : 24
15:08:48 T:140322948486912 DEBUG: DllAvUtilBase: Using libavutil system library
15:08:48 T:140322948486912 DEBUG: DllAvFormat: Using libswresample system library
15:08:48 T:140322948486912 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:08:48 T:140322952853376 DEBUG: Previous line repeats 1 times.
15:08:48 T:140322952853376 INFO: PAPlayer::PrepareStream - Ready
15:08:48 T:140322952853376 DEBUG: PlayFile : OpenFile succeed, play state 1
15:08:48 T:140320540980992 NOTICE: Thread PAPlayer start, auto delete: false
15:08:48 T:140320540980992 DEBUG: PAPlayer::Process - Playback started
15:08:48 T:140320540980992 DEBUG: OnPlayBackStarted : play state was 1, starting 0
15:08:48 T:140322952853376 DEBUG: CGUIInfoManager::SetCurrentSong(/storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/01 - Captain Fantastic And The Brown Dirt Cowboy.flac)
15:08:48 T:140322952853376 DEBUG: Loading additional tag info for file /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/01 - Captain Fantastic And The Brown Dirt Cowboy.flac
15:08:48 T:140322952853376 DEBUG: unrecognized XipComment name: PERFORMER
15:08:48 T:140322952853376 DEBUG: unrecognized XipComment name: TOTALTRACKS
15:08:48 T:140322952853376 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
15:08:48 T:140322952853376 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
15:08:48 T:140322952853376 DEBUG: UPnP: Building didl for object '/storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/01 - Captain Fantastic And The Brown Dirt Cowboy.flac'
15:08:48 T:140322952853376 DEBUG: LIRC: Update - NEW at 1054644:160 0 KEY_OK_UP devinput (KEY_OK_UP)
15:09:16 T:140320775845632 DEBUG: Thread JobWorker 140320775845632 terminating (autodelete)
15:11:30 T:140320767452928 DEBUG: EPG - UpdateFromScraper - updating EPG for channel 'RTÉ One' from client '1'
15:11:30 T:140320767452928 DEBUG: EPG - UpdateFromScraper - updating EPG for channel 'RTÉ Two' from client '1'
15:11:30 T:140322529068800 DEBUG: CPVRTimers - Update - updating timers
15:11:30 T:140322529068800 DEBUG: PVRTimers - UpdateEntries - updated timer 257 on client 1
15:11:30 T:140322529068800 DEBUG: PVRTimers - UpdateEntries - updated timer 259 on client 1
15:13:47 T:140322952853376 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
15:13:47 T:140322952853376 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
15:13:47 T:140322952853376 DEBUG: ------ Window Init () ------
15:14:06 T:140321505650432 INFO: CFileCache::Process - Hit eof.
15:14:28 T:140320540980992 DEBUG: OnQueueNextItem : play state was 2, starting 0
15:14:28 T:140322537461504 NOTICE: Thread JobWorker start, auto delete: true
15:14:28 T:140322537461504 DEBUG: CFileCache::Open - opening </storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/02 - Tower Of Babel.flac> using cache
15:14:28 T:140322117404416 NOTICE: Thread FileCache start, auto delete: false
15:14:28 T:140322537461504 DEBUG: unrecognized XipComment name: PERFORMER
15:14:28 T:140322537461504 DEBUG: unrecognized XipComment name: TOTALTRACKS
15:14:28 T:140322537461504 INFO: AudioDecoder: File is queued
15:14:29 T:140322537461504 INFO: PAPlayer::PrepareStream - Ready
15:14:33 T:140320540980992 DEBUG: OnPlayBackStarted : play state was 2, starting 0
15:14:33 T:140321505650432 DEBUG: Thread FileCache 140321505650432 terminating
15:14:33 T:140320540980992 DEBUG: PAPlayer::ProcessStreams - Stream Freed
15:14:33 T:140322948486912 DEBUG: CActiveAE::DiscardStream - audio stream deleted
15:14:33 T:140322948486912 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:14:33 T:140322952853376 DEBUG: Previous line repeats 1 times.
15:14:33 T:140322952853376 DEBUG: CGUIInfoManager::SetCurrentSong(/storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/02 - Tower Of Babel.flac)
15:14:33 T:140322952853376 DEBUG: Loading additional tag info for file /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/02 - Tower Of Babel.flac
15:14:33 T:140322952853376 DEBUG: unrecognized XipComment name: PERFORMER
15:14:33 T:140322952853376 DEBUG: unrecognized XipComment name: TOTALTRACKS
15:14:33 T:140322952853376 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
15:14:33 T:140322952853376 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
15:14:33 T:140322952853376 DEBUG: UPnP: Building didl for object '/storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/02 - Tower Of Babel.flac'
15:14:33 T:140322537461504 DEBUG: DoWork - Saving file state for audio item /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/01 - Captain Fantastic And The Brown Dirt Cowboy.flac
15:14:33 T:140322537461504 DEBUG: DoWork - Marking audio item /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/01 - Captain Fantastic And The Brown Dirt Cowboy.flac as listened
15:15:03 T:140322537461504 DEBUG: Thread JobWorker 140322537461504 terminating (autodelete)
15:16:30 T:140322529068800 DEBUG: CPVRTimers - Update - updating timers
15:16:30 T:140322529068800 DEBUG: PVRTimers - UpdateEntries - updated timer 257 on client 1
15:16:30 T:140322529068800 DEBUG: PVRTimers - UpdateEntries - updated timer 259 on client 1
15:18:35 T:140322117404416 INFO: CFileCache::Process - Hit eof.
15:18:55 T:140320540980992 DEBUG: OnQueueNextItem : play state was 2, starting 0
15:18:55 T:140322537461504 NOTICE: Thread JobWorker start, auto delete: true
15:18:55 T:140322537461504 DEBUG: CFileCache::Open - opening </storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/03 - Bitter Fingers.flac> using cache
15:18:55 T:140321505650432 NOTICE: Thread FileCache start, auto delete: false
15:18:55 T:140322537461504 DEBUG: unrecognized XipComment name: PERFORMER
15:18:55 T:140322537461504 DEBUG: unrecognized XipComment name: TOTALTRACKS
15:18:56 T:140322537461504 INFO: AudioDecoder: File is queued
15:18:56 T:140322537461504 INFO: PAPlayer::PrepareStream - Ready
15:19:00 T:140320540980992 INFO: PAPlayer::ProcessStream - Stream Finished
15:19:00 T:140322117404416 DEBUG: Thread FileCache 140322117404416 terminating
15:19:00 T:140320540980992 DEBUG: OnPlayBackStarted : play state was 2, starting 0
15:19:00 T:140322948486912 DEBUG: CActiveAE::DiscardStream - audio stream deleted
15:19:00 T:140320540980992 DEBUG: PAPlayer::ProcessStreams - Stream Freed
15:19:00 T:140322948486912 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
15:19:00 T:140322952853376 DEBUG: Previous line repeats 1 times.
15:19:00 T:140322952853376 DEBUG: CGUIInfoManager::SetCurrentSong(/storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/03 - Bitter Fingers.flac)
15:19:00 T:140322952853376 DEBUG: Loading additional tag info for file /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/03 - Bitter Fingers.flac
15:19:00 T:140322952853376 DEBUG: unrecognized XipComment name: PERFORMER
15:19:00 T:140322952853376 DEBUG: unrecognized XipComment name: TOTALTRACKS
15:19:00 T:140322952853376 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
15:19:00 T:140322952853376 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
15:19:00 T:140322952853376 DEBUG: UPnP: Building didl for object '/storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/03 - Bitter Fingers.flac'
15:19:00 T:140322537461504 DEBUG: DoWork - Saving file state for audio item /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/02 - Tower Of Babel.flac
15:19:00 T:140322537461504 DEBUG: DoWork - Marking audio item /storage/multichannel/Captain Fantastic And The Brown Dirt Cowboy (SACD 5.1)/02 - Tower Of Babel.flac as listened
(2013-12-04, 18:16)FernetMenta Wrote: [ -> ]In order to fix this we would need to up to player API. Currently application closes/reopen player on skip. In turn player release the stream and flushes the engine. It would work if engine was not flushed.
FernetMenta - Exactly what I thought! The player is doing something different during skip then what it is doing during normal play. I have only seen your reply now after I had pulled a logfile and replied to @
fritsch.
