Full Version: catching images
Hello!
I use frodo 12.2
I have a small problem, skin does not want to load images from the internet.
I want to say some images loaded without problems some images never to appear,
and if I put a direct link again not loaded image, sometimes loaded image after 30 minutes.
I have a good connection to the Internet and the speed
So this is a bug in xbmc or not.
Thanks in advance
Hello
This is my debug log,you will see a lot errors it is because I work on my skin.
The main problem is that I can not pull image from the Internet specifically, friends avatar I use string name for avatar,
has long been seen in many skin.
When I put the direct link as for example: http://avatar.xboxlive.com/avatar/bingbd...rpic-l.png
still the skin not able to load images.
http://www.xbmclogs.com/show.php?id=92987
In any case thanks, because you want to help.
