2013-12-03, 04:46
Hello,
I have been combing the forums to try and help me make a decision on hardware/software combinations, what to buy, etc. There are a lot of posts here, lots helpful, but almost impossible to look through them all. So I finally decided to make an account and ask for some help!
First, I came from Boxee. I loved that little guy, but after the support was dropped and they stopped updating it, my collection continued to grow, Boxee got sluggish when things started getting into the thousands of media files.. I decided to convert my old HP laptop into an XBMC machine running overtop of Windows 8. This worked, for the most part, however it was also buggy. I blame the laptop and Windows, it would randomly change which display it was displaying on, adjust the resolution, sometimes the IR wouldn't pick up without a reset...
From what I gather from reading here, a NAS is the best way to go for my storage needs. I currently have three 3TB WD Green drives in a Probox USB 3.0 enclosure and it may also be part of my problem. My desktop, at times, struggles to pick up the drives and I have to power cycle the enclosure to get it to work properly. I have been considering a Drobo or Synology NAS enclosure, I like the features a Drobo has, especially the 5N, and it comes in a bit cheaper than the Synology. My first question: are all NAS enclosures that expensive? Is there a cheaper alternative?
I am considering using OpenELEC. I have limited experience in Linux, but am willing to learn and not afraid of time consuming setup processes. Basically, I want an appliance. I loved how I could turn my Boxee on and there it was, ready to go. I currently have my Windows setup to skip loading explorer.exe and simply run Xbmc instead directly after logon. It works, but again, it seems like it has issues. I know OpenELEC has some hardware limitations. Mostly I just want to be able to watch 1080P video with 5.1 audio through HDMI. I want to be able to navigate the menus quickly, I absolutely cannot stand lag.
I have been considering either Intel NUC or an ACER VN2620G-UC887L. I am not sure which is better, I am hoping somebody can give me some advice here as well. Price is a factor, I don't want to get too expensive, but something under $350 would be ideal.
I have also considered an AppleTV2. But the problem is I don't know if I will be updating my storage method before or after (possibly months after) I get my new HTPC box.
The last thing I am wondering is if it is possible to use a USB 10/100/1000 Mbps ethernet adapter with a NAS setup and still enjoy 1080P without stuttering? I am looking at the Intel NUC Red that doesn't include an ethernet port, and instead, a Thunderbolt port. Or, alternatively, would it be possible to use a Thunderbolt to Ethernet adapter with OpenELEC?
TLDR;
Best HTPC that does 1080P video without menu lag for under $350
Best way to do a NAS setup .. Drobo/Synology worth it
OpenELEC or Linux distro
AppleTV2 worth money/time
USB to Ethernet adapter with NAS possible
TLDR;
