2013-12-07, 15:16
Hello. I have experience with XBMC in windows, but am a noob when it comes to linux in general. I installed Ubuntu 13.10 and installed xbmc through the apt-get command. It gave me the 12.0RC version which was older, but I thought "okay". When I began adding tv shows to the database (file structure unchanged from my windows box install), it would add the season art and complete the list. When I navigate into a particular show however, it displays an incomplete screen with some metadata about the show, but fails to list any art/thumbnails for the seasons enclosed. The only keypress that works is enter, which places me back on the list of tv shows. If i navigate through files, it lists the episode with the thumbnail fine. I thought that the problem was because it was the 12.0RC version, so I got version 12.2 and installed it. Alas it didn't change anything and the same issue is present. Also it seems that the library isn't responding to the clean command. If I try to remove all sources and clean the database, the shows remain unchanged.
I know that's a long read, but I tried to explain it in the most efficient way..
Any help would be awesome. Thanks.
