Full Version: video problem after updating to 12.2
Hi all,
I recently finally took the time to update my HTPC to xbmc 12.2 from XBMC 11.X (don't remember which one), and some videos that used to work fine now see a significant drop in frame rate, followed by a "catch up" (it slows down and accelerates continuously).
My machine is a Zotac zbox nano ad-10 (specs: here)
xbmc 12.2 (Git:32b1a5e (compiled: May 2 2013))
Debug log: http://pastebin.com/8064bU5e
Please tell me if you need any other info.
Any help would be appreciated!
Cheers,
dekox
look at this: http://forum.xbmc.org/showthread.php?tid=174854
you won't have much fun with an E350 without hardware acceleration.
Thanks. Why do I suddenly need hardware acceleration? It used to work on xbmc 11.
This tutorial is really quite technical for a complete Linux novice like me. Is there one which is a bit more noob friendly?
you never had any hardware acceleration with your E-350, so you probably didn't play any HD material(or only low bitrate 720p). And no, there is no other way to get it running at the moment.
