Hi guys,
I'm looking for some advice, I've currently got a HTPC running Windows 8.1 with the AMD A6-3500 CPU, connected via HDMI to my living room TV.
I'm trying to get xbmc configured in such a way that it requires very little (or none at all) administration via keyboard and mouse.
I've made some tweaks to Windows 8.1 to make it start in 'desktop mode' with XBMC running at startup and also disabled password/user login. This seems to work well and fluently for the most part, but I can't seem to get the additional functionality I'm looking for to work.
I'd like to integrate some emulators and PC games and control them using a Xbox 360 controller. I've experimented a little using Xbmclauncher to ensure that XBMC doesn't loose focus when launching games, however I struggled to get it to work properly as it prevented a autohotkey file from running, which prevented me from using my harmony remote. I'm currently using Advanced Launcher to launch my PC games in conjunction with this script:
pssuspend XBMC.exe
cd "C:\Program Files (x86)\the elder scrolls v skyrim"
tesv.exe %1
pssuspend -r XBMC.exe
However I've found that xbmc doesn't always return to the set resolution after playing a game in any resolution other than 1080. often it's ultra zoomed meaning I'm unable to navigate xbmc until I restart it, which means that I have to rdp/Vnc onto the htpc with my laptop and restart xbmc manually.
Is there an easier way I could be doing this? Does anybody else have any advice for a keyboardless setup?
I find it easiest to close xbmc when launching games - its less problematic. I can post the AutoHotKey script that I've been using with advanced launcher and battlefield 4 (I was using batch files before but AHK works better) when I get home if you like.
Also I find using eventghost to assign a remote button to kill and restart xbmc invaluable.
Thanks man, I've also been reading about steam BPM which seems like a viable option for launching the games. So presumably I could modify and use your autohotkey script to close xbmc and open Steam BPM?
I have just switched to Windows to enable better support for Roms and Steam so would be interested in this script. Waiting for the servers to stabilise again so I can install Advanced Launcher and try some emulators out, but I have always found RCB seems to work a lot better than AL for emulation if you are planning on some retro gaming.
Have you ever considered launching your roms/emulators from within Steam BPM? I've seen some examples of this being done, I might have to give it a go myself.
Here is the ahk script for bf4
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
; #Warn ; Enable warnings to assist with detecting common errors.
#SingleInstance force
SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir e:\games\origin-games\Battlefield 4
Run, bf4.exe
sleep, 2000
WinKill, XBMC
;Run %comspec% /c taskkill /f /im XBMC.exe
Process, Wait, bf4.exe
sleep 15000
Process, WaitClose, bf4.exe
Run %comspec% /c taskkill /f /im iexplore.exe
;WinKill, Origin
;WinKill, iexplore
Run, "c:\program files (x86)\xbmc\xbmc.exe" &
(2013-12-12, 15:13)benholtby Wrote: [ -> ]I have just switched to Windows to enable better support for Roms and Steam so would be interested in this script. Waiting for the servers to stabilise again so I can install Advanced Launcher and try some emulators out, but I have always found RCB seems to work a lot better than AL for emulation if you are planning on some retro gaming.
Same, I prefer RCB for emulators and AL for stand alone pc games.
(2013-12-12, 15:22)denz13 Wrote: [ -> ]Have you ever considered launching your roms/emulators from within Steam BPM? I've seen some examples of this being done, I might have to give it a go myself.
I tried adding a game once, but I couldnt add any fanart to steam bpm, so now I just use advnced launcher. Plus you would need to add each rom as a separate launcher.
(2013-12-12, 22:12)teeedubb Wrote: [ -> ]I tried adding a game once, but I couldnt add any fanart to steam bpm, so now I just use advnced launcher. Plus you would need to add each rom as a separate launcher.
Oh that would be fun with MAME...
(2013-12-12, 22:12)teeedubb Wrote: [ -> ]Here is the ahk script for bf4
Run, bf4.exe
sleep, 2000
WinKill, XBMC
sleep 15000
;WinKill, Origin
;WinKill, iexplore
so just save this to a .bat file and run it? this will close XBMC and start BF4? and will restart XBMC after BF4 is closed?
thanks
Save the script as "Battlefield 4.ahk", make any changes to file locations, install AutoHotKey and after installing it right click on the ahk file and select compile, youll end up with a file called "Battlefield 4.exe". I point advanced launcher to the directory full of similar .exe's. Yes it closes xbmc then restarts it when bf4 is exited.
In bf3, punkbuster kicked you out if you had autohotkey script running.
(2013-12-19, 18:34)marsilainen Wrote: [ -> ]In bf3, punkbuster kicked you out if you had autohotkey script running.
I havent had any problems with bf4 + ahk, but here is a batch file I use to launch gta4 which is similar to bf4 as another process is launched before the actual game process:
@echo off
set XBMCLaunchCmd="C:\Program Files (x86)\XBMC\XBMC.exe"
set GAMEWorkingDir="E:\games\int-games\Grand Theft Auto IV"
set GAMELaunchCmd="GTAIV.exe"
set GAMEProcess="RGSC.exe"
set XBMCPreLaunchCmd=""
set VBSLaunch="%appdata%\XBMC\userdata\addons\script.steam.launcher\resources\LaunchXBMC.vbs"
echo Starting %GAMELaunchCmd%...
cd /d %GAMEWorkingDir%
cscript //B //Nologo %VBSLaunch% "%GAMEWorkingDir%\%GAMELaunchCmd%"
:killxbmc
echo Stopping XBMC...
taskkill /f /IM xbmc.exe>nul 2>nul
:gameprocessloop
echo Loop while GAMELaunchCmd open
tasklist /nh /fi "imagename eq %GAMELaunchCmd%" | find /i "%GAMELaunchCmd%" >nul && (
echo %GAMELaunchCmd% is running, loop
timeout 1
goto gameprocessloop
echo GAMELaunchCmd is not running, now check for GAMEProcess
echo Loop while GAMEProcess open
tasklist /nh /fi "imagename eq %GAMEProcess%" | find /i "%GAMEProcess%" >nul && (
echo %GAMEProcess% - %GAMELaunchCmd% is running, loop
timeout 1
echo GAMEProcess is not running, launch XBMC
cscript //B //Nologo %VBSLaunch% %XBMCLaunchCmd%
echo Check for 5 seconds to see if GAMEProcess has been restarted for what ever reason
tasklist /nh /fi "imagename eq %GAMEProcess%" | find /i %GAMEProcess% >nul && (
echo GAMEProcess is running again after 1 second
goto killxbmc
echo GAMEProcess is not running, wait one second, try again.. 1
timeout 1
echo GAMEProcess is running again after 2 seconds
goto killxbmc
echo GAMEProcess is not running, wait one second, try again.. 2
timeout 1
echo GAMEProcess is running again after 3 seconds
goto killxbmc
echo GAMEProcess is not running, wait one second, try again.. 3
timeout 1
echo GAMEProcess is running again after 4 seconds
goto killxbmc
echo GAMEProcess is not running, wait one second, try again.. 4
timeout 1
echo GAMEProcess is running again after 5 seconds, that was close...
goto killxbmc
echo GAMEProcess is not running, wait one second, try again.. 5
timeout 1
goto killxbmc
echo GAMEProcess is not running after 5 seconds, user must have quit
echo Script is exiting
EDIT: you need the vbs script file from rom collection browser or steam launcher for this to work.
RCB and Advanced Launcher are using the same external emulators applications and mostly start them using the same command lines. How game emulation could be better on one and not on the other?
(2013-12-20, 00:32)teeedubb Wrote: [ -> ] (2013-12-19, 18:34)marsilainen Wrote: [ -> ]In bf3, punkbuster kicked you out if you had autohotkey script running.
@echo off
:killxbmc
:gameprocessloop
timeout 1
timeout 1
goto killxbmc
timeout 1
goto killxbmc
timeout 1
goto killxbmc
timeout 1
goto killxbmc
timeout 1
goto killxbmc
timeout 1
goto killxbmc
Are you pointing Advance Launcher to that Batch file?
Also, What VBS script file are you referring to and where do I find it?
Hobs
Yeah I think I setup AL as a file launcher (the one for emulators), with explorer.exe as the emulator and the bat/ahk script files as the roms, but I'd need to double check.
Probably best to get the vbs script from ROM collection browser, I've since modified the vbs script for my steam-launcher add on and can't tell you which version to use off the top of my head... Which reminds me I need to update my batch files as none of them will probably work now...
