General Support
Android
> Pivos Xios Delete using Volume Down
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
chris8837
2013-12-12, 05:04
I have a xios and I'm trying to edit remote or keymap to delete using the volume down button.
Any idea how to do this?
Eleazar Coding
2013-12-13, 02:13
You should probably find quicker assistance at
www.pivosforums.com
for this.
Ned Scott
2013-12-13, 02:20
Create an "appcommand.xml" file to go along side the keyboard.xml file:
https://raw.github.com/xbmc/xbmc/master/...ommand.xml
there you can edit the volume down button for the specific window you want, just like the normal keymap files.
chris8837
2013-12-15, 20:34
you awesome!!
Thanks for the reply. Now I just have to figure it out. HAHA
General Support
Android
