2013-12-14, 00:58
Hello All,
I am trying to load various playlist files - mostly .m3u and .wpl files. What I want to do is load them, and then be able to query using "Playlist.GetItems" and return the individual songs in the playlist. However, when I do this, I only get the title of the playlist returned. Here is my sequence of commands:
This successfully loads the playlist. I then call "Player.GetItems" in an attempt to return the songs in this playlist:
The response is as follows:
This is useless to me. What I need to know is the names of the songs inside this playlist. Is there a way to access that?
Another thing that is weird is that if I use "Player.Open" to call the playlist, I can call "Playlist.GetItems" and it does return track names, but interestingly enough, only under playlistid=1, even when dealing with audio.
Is it possible to return a list of items in a playlist?
{"jsonrpc": "2.0", "method": "Playlist.Add","params":{"playlistid":0,"item":{"file":"file://C:/Documents and Settings/Smith/Desktop/Playlist.m3u"}},"id":789}
{"jsonrpc":"2.0", "id":789, "method":"Playlist.GetItems","params":{"playlistid":0,"properties":["title"]}}
{"id":789,"jsonrpc":"2.0","result":{"items":[{"label":"Playlist.m3u","title":"","type":"unknown"}],"limits":{"end":1,"start":0,"total":1}}}
