Full Version: Unexpected end of playing HD mkv video file
I have not able to play successfully, i.e. till the end, on any of the HD mkv video file I have on my PCH-C300 media player.
I installed xbmc on my winxp laptop, and streaming the video from the PCH-C300 usb attached drive.
I attached the xbmc.log here to start off reviewing of this problem I have;
22:25:31 T:1552 NOTICE: -----------------------------------------------------------------------
22:25:31 T:1552 NOTICE: Starting XBMC (12.2 Git:20130502-32b1a5e), Platform: WindowsXP Professional SP3 32-bit, build 2600. Built on May 2 2013 (compiler 1600)
22:25:31 T:1552 NOTICE: Intel® Core™2 Duo CPU T7500 @ 2.20GHz
22:25:31 T:1552 NOTICE: Desktop Resolution: 1920x1200 32Bit at 60Hz
22:25:31 T:1552 NOTICE: Running with administrator rights
22:25:31 T:1552 NOTICE: Aero is disabled
22:25:31 T:1552 NOTICE: special://xbmc/ is mapped to: D:\Program Files\XBMC
22:25:31 T:1552 NOTICE: special://xbmcbin/ is mapped to: D:\Program Files\XBMC
22:25:31 T:1552 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\Lim Ming Liang\Application Data\XBMC\userdata
22:25:31 T:1552 NOTICE: special://home/ is mapped to: C:\Documents and Settings\Lim Ming Liang\Application Data\XBMC\
22:25:31 T:1552 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\Lim Ming Liang\Application Data\XBMC\cache
22:25:31 T:1552 NOTICE: The executable running is: D:\Program Files\XBMC\XBMC.exe
22:25:32 T:1552 NOTICE: Local hostname: limmi01-xp
22:25:32 T:1552 NOTICE: Log File is located: C:\Documents and Settings\Lim Ming Liang\Application Data\XBMC\xbmc.log
22:25:32 T:1552 NOTICE: -----------------------------------------------------------------------
22:25:32 T:1552 NOTICE: Found 1 Lists of Devices
22:25:32 T:1552 NOTICE: Enumerated DirectSound devices:
22:25:32 T:1552 NOTICE: Device 1
22:25:32 T:1552 NOTICE: m_deviceName : {bd6dd71a-3deb-11d1-b171-00c04fc20000}
22:25:32 T:1552 NOTICE: m_displayName : SoundMAX HD Audio
22:25:32 T:1552 NOTICE: m_displayNameExtra: DirectSound: SoundMAX HD Audio
22:25:32 T:1552 NOTICE: m_deviceType : AE_DEVTYPE_PCM
22:25:32 T:1552 NOTICE: m_channels : FL,FR
22:25:32 T:1552 NOTICE: m_sampleRates : 96000
22:25:32 T:1552 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
22:25:32 T:1552 NOTICE: load settings...
22:25:32 T:1552 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:25:32 T:1552 NOTICE: loading special://masterprofile/guisettings.xml
22:25:32 T:1552 NOTICE: Getting hardware information now...
22:25:32 T:1552 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:25:32 T:1552 NOTICE: Loaded playercorefactory configuration
22:25:32 T:1552 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:25:32 T:1552 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:25:32 T:1552 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:25:32 T:1552 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
22:25:32 T:1552 NOTICE: Contents of special://profile/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>524288000</cachemembuffersize>
</network>
<samba>
<doscodepage />
<clienttimeout>10</clienttimeout>
<statfiles>false</statfiles>
</samba>
</advancedsettings>
22:25:32 T:1552 NOTICE: Default DVD Player: dvdplayer
22:25:32 T:1552 NOTICE: Default Video Player: dvdplayer
22:25:32 T:1552 NOTICE: Default Audio Player: paplayer
22:25:32 T:1552 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:25:32 T:1552 NOTICE: Log level changed to 0
22:25:32 T:1552 NOTICE: Loading media sources from special://masterprofile/sources.xml
22:25:32 T:4500 NOTICE: Thread CSoftAE start, auto delete: false
22:25:32 T:1552 NOTICE: Running database version Addons15
22:25:32 T:4500 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:10576, P:624, O:3528.
22:25:32 T:6132 NOTICE: Thread XBMC Peripherals start, auto delete: false
22:25:32 T:6088 NOTICE: Previous line repeats 1 times.
22:25:32 T:6088 NOTICE: Thread CRemoteControl start, auto delete: false
22:25:33 T:1552 NOTICE: Found screen: Default Monitor on NVIDIA Quadro FX 570M, adapter 0.
22:25:33 T:1552 NOTICE: Primary mode: 1920x1200 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 320x200 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 320x240 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 400x300 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 480x360 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 512x384 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 640x400 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1400x1050 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1440x900 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1600x1200 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Additional mode: 1920x1200 @ 60.00 - Full Screen
22:25:33 T:1552 NOTICE: Checking resolution 16
22:25:34 T:1552 NOTICE: Running database version Addons15
22:25:34 T:1552 NOTICE: Running database version ViewModes4
22:25:34 T:1552 NOTICE: Running database version Textures13
22:25:34 T:1552 NOTICE: Running database version MyMusic32
22:25:34 T:1552 NOTICE: Running database version MyVideos75
22:25:34 T:1552 NOTICE: Running database version TV22
22:25:34 T:1552 NOTICE: Running database version Epg7
22:25:34 T:1552 NOTICE: initializing playlistplayer
22:25:34 T:1552 NOTICE: DONE initializing playlistplayer
22:25:34 T:1552 NOTICE: initialize done
22:25:34 T:5072 NOTICE: Thread XBPyThread start, auto delete: false
22:25:34 T:1552 NOTICE: Running the application...
22:25:34 T:5072 NOTICE: -->Python Interpreter Initialized<--
22:25:34 T:5072 NOTICE: StorageServer Module loaded RUN
22:25:34 T:5072 NOTICE: StorageClient-2.5.2 Starting server
22:25:34 T:5072 NOTICE: StorageServer-2.5.2 Storage Server starting C:\Documents and Settings\Lim Ming Liang\Application Data\XBMC\cache\commoncache.db
22:25:34 T:2540 NOTICE: Thread Jobworker start, auto delete: true
22:25:34 T:1552 NOTICE: ES: Starting event server
22:25:34 T:1548 NOTICE: Thread CTCPServer start, auto delete: false
22:25:34 T:2620 NOTICE: Thread CEventServer start, auto delete: false
22:25:34 T:2620 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:25:34 T:2620 NOTICE: UDP: Listening on port 9777
22:25:34 T:1536 NOTICE: Thread CRssReader start, auto delete: false
22:25:37 T:5132 NOTICE: Thread Jobworker start, auto delete: true
22:25:37 T:5132 ERROR: InputStream: Error opening, V:\Movies\Star.Trek.Into.Darkness.2013.1080p.BluRay.AVC.TrueHD.7.1-PublicHD\BDMV\index.bdmv
22:25:37 T:3696 NOTICE: Thread Jobworker start, auto delete: true
22:25:37 T:5132 ERROR: InputStream: Error opening, U:\Movies\THE_AVENGERS_BD2D\BDMV\index.bdmv
22:25:37 T:5132 ERROR: InputStream: Error opening, U:\Movies\Prometheus.2012.1080p.BluRay\BDMV\index.bdmv
22:25:37 T:3696 ERROR: InputStream: Error opening, U:\Movies\PELHAM_123\BDMV\index.bdmv
22:25:37 T:3696 ERROR: InputStream: Error opening, T:\Video\Knight.and.Day.2010.BluRay.1080p.AVC.DTS-HD.MA.5.1-HDChina\BDMV\index.bdmv
22:25:37 T:5132 ERROR: InputStream: Error opening, T:\Video\The Exorcist 1973 1080p Blu-ray VC-1 DTS-HD MA 5.1\BDMV\index.bdmv
22:25:37 T:3696 ERROR: InputStream: Error opening, T:\Video\NATIONAL_LAMPOONS_VACATION\BDMV\index.bdmv
22:25:37 T:3696 ERROR: InputStream: Error opening, T:\Video\Enter the Dragon 1973 1080p Blu-Ray VC-1 DD5.1\BDMV\index.bdmv
22:25:48 T:4352 NOTICE: Thread Background Loader start, auto delete: false
22:25:53 T:5132 ERROR: XFILE::CDirectory::GetDirectory - Error getting V:\TV Series\
22:25:53 T:5132 ERROR: Error Getting Directory (V:\TV Series\)
22:25:53 T:6104 NOTICE: Thread Background Loader start, auto delete: false
22:26:07 T:2944 NOTICE: Previous line repeats 2 times.
22:26:07 T:2944 NOTICE: Thread Jobworker start, auto delete: true
22:26:13 T:1552 NOTICE: DVDPlayer: Opening: U:\TV Series\Three Kingdoms\Season 1\Three Kingdoms s01e03 关羽温酒斩华雄.mkv
22:26:13 T:1552 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:26:13 T:3352 NOTICE: Thread CDVDPlayer start, auto delete: false
22:26:13 T:3352 NOTICE: Creating InputStream
22:26:17 T:3352 NOTICE: Creating Demuxer
22:26:47 T:3352 NOTICE: Opening video stream: 0 source: 256
22:26:47 T:3352 NOTICE: Creating video codec with codec id: 28
22:26:47 T:3352 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
22:26:47 T:3352 NOTICE: Creating video thread
22:26:47 T:3352 NOTICE: Opening audio stream: 1 source: 256
22:26:47 T:3352 NOTICE: Finding audio codec for: 86019
22:26:47 T:3352 NOTICE: Creating audio thread
22:26:47 T:3352 NOTICE: Opening Subtitle stream: 3 source: 256
22:26:47 T:2904 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
22:26:47 T:2904 NOTICE: running thread: video_thread
22:26:47 T:5728 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
22:26:47 T:5728 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
22:26:47 T:5728 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
22:26:47 T:2904 NOTICE: fps: 25.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
22:26:47 T:2904 NOTICE: Display resolution DESKTOP : 1920x1200 @ 60.00 - Full Screen (16)
22:26:48 T:4500 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:11520, P:296, O:3840.
22:26:50 T:5728 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
22:26:50 T:3352 NOTICE: CDVDPlayer::OnExit()
22:26:50 T:3352 NOTICE: DVDPlayer: eof, waiting for queues to empty
22:26:50 T:3352 NOTICE: DVDPlayer: closing audio stream
22:26:50 T:3352 NOTICE: Closing audio stream
22:26:50 T:3352 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
22:26:50 T:5728 NOTICE: thread end: CDVDPlayerAudio::OnExit()
22:26:50 T:3352 NOTICE: Waiting for audio thread to exit
22:26:50 T:3352 NOTICE: Closing audio device
22:26:50 T:3352 NOTICE: Deleting audio codec
22:26:50 T:3352 NOTICE: DVDPlayer: closing video stream
22:26:50 T:3352 NOTICE: Closing video stream
22:26:50 T:3352 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
22:26:50 T:2904 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
22:26:50 T:3352 NOTICE: waiting for video thread to exit
22:26:50 T:2904 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
22:26:50 T:2904 NOTICE: thread end: video_thread
22:26:50 T:3352 NOTICE: deleting video codec
22:26:50 T:3352 NOTICE: DVDPlayer: closing subtitle stream
22:26:50 T:3352 NOTICE: Closing subtitle stream
22:26:50 T:3352 NOTICE: CDVDPlayer::OnExit() deleting demuxer
22:26:50 T:3352 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:26:51 T:4500 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:10576, P:608, O:3528.
22:26:51 T:4840 NOTICE: Thread Background Loader start, auto delete: false
22:26:51 T:1552 NOTICE: CDVDPlayer::CloseFile()
22:26:51 T:1552 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:26:51 T:1552 NOTICE: DVDPlayer: waiting for threads to exit
22:26:51 T:1552 NOTICE: DVDPlayer: finished waiting
22:26:51 T:1984 NOTICE: Thread Jobworker start, auto delete: true
22:27:11 T:1552 NOTICE: DVDPlayer: Opening: U:\TV Series\Three Kingdoms\Season 1\Three Kingdoms s01e08 凤仪亭父子挑兵戈.mkv
22:27:11 T:1552 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:27:11 T:1888 NOTICE: Thread CDVDPlayer start, auto delete: false
22:27:11 T:1888 NOTICE: Creating InputStream
22:27:13 T:1888 NOTICE: Creating Demuxer
22:27:44 T:1888 NOTICE: Opening video stream: 0 source: 256
22:27:44 T:1888 NOTICE: Creating video codec with codec id: 28
22:27:44 T:1888 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
22:27:44 T:1888 NOTICE: Creating video thread
22:27:44 T:1888 NOTICE: Opening audio stream: 1 source: 256
22:27:44 T:1888 NOTICE: Finding audio codec for: 86019
22:27:44 T:1888 NOTICE: Creating audio thread
22:27:44 T:1888 NOTICE: Opening Subtitle stream: 3 source: 256
22:27:44 T:5084 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
22:27:44 T:5084 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
22:27:44 T:5084 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
22:27:44 T:4804 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
22:27:44 T:4804 NOTICE: running thread: video_thread
22:27:44 T:4804 NOTICE: fps: 25.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
22:27:44 T:4804 NOTICE: Display resolution DESKTOP : 1920x1200 @ 60.00 - Full Screen (16)
22:27:44 T:4500 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:11520, P:688, O:3840.
22:28:04 T:5084 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:11520, P:1344, O:3840.
22:28:09 T:5084 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
22:28:09 T:4804 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
22:28:10 T:1888 NOTICE: CDVDPlayer::OnExit()
22:28:10 T:1888 NOTICE: DVDPlayer: eof, waiting for queues to empty
22:28:10 T:1888 NOTICE: DVDPlayer: closing audio stream
22:28:10 T:1888 NOTICE: Closing audio stream
22:28:10 T:1888 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
22:28:10 T:5084 NOTICE: thread end: CDVDPlayerAudio::OnExit()
22:28:10 T:1888 NOTICE: Waiting for audio thread to exit
22:28:10 T:1888 NOTICE: Closing audio device
22:28:10 T:1888 NOTICE: Deleting audio codec
22:28:10 T:1888 NOTICE: DVDPlayer: closing video stream
22:28:10 T:1888 NOTICE: Closing video stream
22:28:10 T:1888 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
22:28:10 T:1888 NOTICE: waiting for video thread to exit
22:28:10 T:4804 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
22:28:10 T:4804 NOTICE: thread end: video_thread
22:28:10 T:1888 NOTICE: deleting video codec
22:28:10 T:1888 NOTICE: DVDPlayer: closing subtitle stream
22:28:10 T:1888 NOTICE: Closing subtitle stream
22:28:10 T:1888 NOTICE: CDVDPlayer::OnExit() deleting demuxer
22:28:10 T:1888 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:28:10 T:4500 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:10576, P:640, O:3528.
22:28:10 T:3548 NOTICE: Thread Jobworker start, auto delete: true
22:28:10 T:5396 NOTICE: Thread Background Loader start, auto delete: false
22:28:10 T:1552 NOTICE: CDVDPlayer::CloseFile()
22:28:10 T:1552 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:28:10 T:1552 NOTICE: DVDPlayer: waiting for threads to exit
22:28:10 T:1552 NOTICE: DVDPlayer: finished waiting
22:28:10 T:3544 NOTICE: Thread Jobworker start, auto delete: true
22:28:30 T:1552 NOTICE: Storing total System Uptime
22:28:30 T:1552 NOTICE: Saving settings
22:28:30 T:1552 NOTICE: stop all
22:28:30 T:1552 NOTICE: ES: Stopping event server
22:28:30 T:1552 NOTICE: stopping zeroconf publishing
22:28:31 T:2620 NOTICE: ES: UDP Event server stopped
22:28:31 T:1552 NOTICE: stop sap announcement listener
22:28:31 T:1552 NOTICE: clean cached files!
22:28:31 T:1552 NOTICE: unload skin
22:28:32 T:5072 NOTICE: StorageServer-2.5.2 Closed down
22:28:32 T:1552 NOTICE: stop python
22:28:32 T:1552 NOTICE: stopped
22:28:32 T:1552 NOTICE: destroy
22:28:32 T:1552 NOTICE: closing down remote control service
22:28:32 T:1552 NOTICE: unload sections
22:28:32 T:1552 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
22:28:32 T:1552 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
22:28:32 T:1552 NOTICE: application stopped...
Anyone can help me on this ? Or I should post more info ?
I still encountered frequent buffering pauses while watching 1080p HD movie "Braveheart", and I turn on the debug log and paste it in
http://pastebin.com/Gya7ipZT .
Much appreciate someone can give me some guidance on this, or another forum to discuss this subject.
Thank you.
Lim ML
I have captured a screenshots showing some resource statistics, but do not know how to interpret them. The link to the screen-shot
http://postimg.org/image/e5um4lo2j/
, and seeking for some expert advices.
Hopefully someone can throw some light on this. Thank you in advance.
