I've added the Unofficial Jynxbox M6 XBMC Pure Linux version with the revert solution from Biatsch
AuXBoX:
Did you test Biatsch's revert solution? Would be nice to have a second opinion before I test it too.
tinker
(2014-03-18, 18:30)Biatsch Wrote: [ -> ]I tested it twice
Biatsch:
That's just what I would done too. I give it a try later today.
tinker
(2014-03-18, 18:47)tinker Wrote: [ -> ] (2014-03-18, 18:30)Biatsch Wrote: [ -> ]I tested it twice
Biatsch:
tinker
Recovery don´t work after reverting from jynxrom use files within update_spi_mx_20130805 AFTER REVERT FROM JYNXBOX.zip and Flash spi manually and all is done box will work originally
uploading true 1080p Rom from geniatech
https://www.dropbox.com/sh/1r3anv4hfubi5wr/Ss2bD31f9Q
(2014-03-18, 20:45)Biatsch Wrote: [ -> ]Recovery don´t work after reverting from jynxrom use files within update_spi_mx_20130805 AFTER REVERT FROM JYNXBOX.zip and Flash spi manually and all is done box will work originally
uploading true 1080p Rom from geniatech https://www.dropbox.com/sh/1r3anv4hfubi5wr/Ss2bD31f9Q
Will try with ATV520E later tonight. Thanks for your work.
seems like xbmc gotham on Android su....... it isnt fast enough will Flash jynxbox again is much faster
Biatsch & AuXBoX:
Nope, couldn't revert to Android using your latest SD boot card. When I ran uboot_MX.cmd (on a Windows XP machine), I was given an error message. Here is the output of dd.exe:
Quote:G:\>set src=.\uboot_MX.bin
G:\>set dst=\\?\Device\Harddisk1\Partition0
G:\>dd if=/dev/zero of=.\sd_bak bs=1 count=0x60000
rawwrite dd for windows version 0.6beta3.
Written by John Newbigin <[email protected]swin.edu.au>
This program is covered by terms of the GPL Version 2.
393216+0 records in
393216+0 records out
G:\>dd if=\\?\Device\Harddisk1\Partition0 of=.\sd_bak bs=512 count=1
Written by John Newbigin <[email protected]>
1+0 records in
1+0 records out
G:\>dd if=.\uboot_MX.bin of=.\sd_bak bs=1 count=444
Error opening input file: 2 The system cannot find the file specified
G:\>dd if=.\uboot_MX.bin of=.\sd_bak bs=512 seek=1 skip=1
G:\>echo Are sure write to \\?\Device\Harddisk1\Partition0 ? Dangrous!!!
G:\>pause
Press any key to continue . . .
G:\>dd if=.\sd_bak of=\\?\Device\Harddisk1\Partition0 bs=512
768+0 records in
768+0 records out
G:\>pause
Hope this helps.
tinker
(2014-03-18, 21:56)tinker Wrote: [ -> ]Biatsch & AuXBoX:
393216+0 records in
1+0 records in
1+0 records out
G:\>pause
768+0 records in
768+0 records out
G:\>pause
Hope this helps.
tinker
put the sdcard in your box with recovery start forgot to cancel uboot.cmd.......... u dont Need that exe important to work are the files
iam cancelling the files u dont Need within zip
sorry forgot to delete them .... ;(
within description ,too LOL (used geniatech bootcard as base) will be fixed.......... just put the files on sd and boot via recovery and wait .............. after that........... when Android booted up ....... cancel all files on sd and copy the ones from spi revert and bootup in recovery...... Flash spi and all is done !!!!!
SORRY FOR WRONG DESCRIPTION !!!!!
Biatsch:
Should I just re-download the .zip from your link above or will you re-post it?
Also, should I try to revert without the Android image file, then use the recovery menu to update it?
tinker
(2014-03-18, 22:30)tinker Wrote: [ -> ]Biatsch:
tinker
u can use the one u downloaded just put all files in root of sd , start ur box with toothpin and wait until Flash procedure is finished ... (Android is booted)
(than download spi revert and copy content to sd) boot via toothpin and Flash spi ......... all done
u can redownload revert but u dont have to ..... some files are deleted and description is changed ....... so nothing important for flashing
