2014-09-27, 14:06
(2014-09-26, 23:57)AuXBoX Wrote: [ -> ](2014-09-26, 19:55)andriszz Wrote: [ -> ](2014-09-26, 13:09)AuXBoX Wrote: [ -> ]The first one
Ok. When i'm waiting for cable, could you please write what can i do next? If its something similar with this instruction (HOW TO BURN IMAGE ATV1200 with RS232.rar from https://www.dropbox.com/home/Linux%20XBMC?select=) that could you please tell me more about serial cable connection.
This is my box - (http://postimg.org/image/8pnykup3d/). I marked with red the connection place for serial cable. Is that correct ? For example, if i have this cable (/www.ebay.co.uk/itm/USB-TTL-Serial-Adapter-UART-CH340G-Arduino-ATMega-DTR-6-pin-w-cables-/121440571323?pt=UK_Computing_Other_Computing_Networking&hash=item1c466c0fbb) then how many pins i need connect to box and where i need to connect them (box have 6 connection places) ?
The serial is at top right of picture and you only use 3 of the 4 connections leaving the red (power) off
Ok, understand. Now waiting for cable to restore my ATV1200 to working state.
One more question: i'm still tryin various methods with rescue sd. In 4pda forum i found a link to this recovery sd card zip (https://www.dropbox.com/s/hjtnay0pv9r5t1s/var2.zip). This recovery card zip is a little bit different from those i saw before. It contains 9 files (aml_autoscript, ethmac.efuse, factory_update_param.aml, factory_update_param.ubt, spi_MX.bin, u-boot.bin, uImage, uImage_recovery, update_MX_20130506.img).
aml.autoscript info:
'VĖ"NwQÅ. ė To× ć if mmcinfo
then
if fatexist mmc 0:1 u-boot.bin
then
if fatload mmc 0 82000000 u-boot.bin
then
sf probe 2
sf erase 0 400000
mmcinfo
sf write 82000000 0 60000
nand info
nand scrub
reset
fi
fi
fi
ethmac.efuse info:
$11:22:33:44:55:66
11:22:33:44:55:67
11:22:33:44:55:68
11:22:33:44:55:69
11:22:33:44:55:99
11:22:33:44:55:77
factory_update_param.aml info:
--set_efuse_version=2
--set_efuse_ethernet_mac=/sdcard/ethmac.efuse
--wipe_cache
--wipe_date
--update_package=/sdcard/update_MX_20130506.img
--wipe_media
factory_update_param.ubt info:
'VŽ µ\P£Z* € Ņ;żø geniatech auto script x echo upgrade spi ...
if mmcinfo
then
if fatexist mmc 0:1 ${spifile}
then
nand erase 0
run burnspi
reset
fi
fi
I upgraded my box from this zip (i think that it didnt finished all upgrade process succesfully) and after that i can boot into Android but i LOST MY MAC ADRESS SETTINGS. Of course, its not "normal boot" because i must have rescue sd card in the box (which contains files from 4.2upgrade from http://mygica.ca/forum/download/file.php?id=71) and also i need to shorten pins. As i understand, when i shorten pins my box try to boot to recovery but it fails and then the Android is loaded.
My question - how can i restore my mac adress to access wifi network? When i flashed my box from this zip it changed my mac adress? Maybe Android can't see my mac adress because spi is broken (boot is only possible with rescue sd and pin shortening)?
UPDATE 12.10.2014.: I wont be able to acess wifi (no mac adress) because there was problems with SPI. I unbricked my box (see post below) and now everything is working correctly.
