Hello, I have latest XBMC release. If i enable PVR feature, the XBMC freezes. Next problem - i did not find PVR clients. Could zou help me ?
You need to give more information. First of all, are you using Windows or Linux?
Okay, you need to install the corresponding PVR addon for your backend, then enable it, and only after that enable live TV in XBMC. What backend are you using?
I use tvheadend. Could you send me the link for PVR addon ?
Run "apt-cache search tvheadend", it will show you the package name. Then you just install it with apt-get install and restart XBMC.
The backend is installed. There is no problem. The problem is that a PVR addon missing
in XBMC.
If you had actually run apt-cache search tvheadend you would have seen the package called "xbmc-pvr-tvheadend-hts" which is what you should install.
You are right. Thanks a lot.
