2013-12-15, 21:36
I'm trying to install the Live XBMC, and have followed the quick start instructions, however everytime I load it from my USB stick, it says the following:
SYSLINUX 4.06 EDD, etc.
Loading the boot file...
Booting...
It then fails and goes to a generic Windows Boot Manager screen.
Windows failed to start. A recent hardware or software change, etc.
FYI the file it's referencing is \Boot\BC
Status: 0cx000000f
Info: The Boot Configuration Data for your PC is missing or contains errors.
I do have a 500gb HDD installed that has Windows 7 on it, however I don't use this install, so I'd like to just install over top of it using the XBMCbuntu install. To even bypass this error though, I've tried to remove the HDD all together so the only device to read is my USB stick.
I know I could install the Windows version, however that copy of Windows is not registered and will expire in a week or two. Also just hoping to use this machine for XBMC.
As for hardware. This is an Intel Core2Quad Q6600, with an nVidia GTX 260 in it.
The version I downloaded was from http://mirrors.xbmc.org/releases/XBMCbuntu/ and is "xbmcbuntu-12.2.Intel-NVIDIA.iso"
I believe that's the relevant information. Anything else, just ask.
Booting...
Status: 0cx000000f
