Full Version: Windows media remote compatibility and config
Dear Guys,
Bit of a noob here - just putting together a Intel NUC with Win7 and had a few questions ;
1) Have a xbox media remote (the black one not the old white one) - from what I understand with a registry fix this should work ok with xbmc ?
2) I believe there is a way to boot straight into xbmc when starting up the NUC ? again is that a reg fix ?
3) Also with picking up network drives/folders (with movies. music. tv etc) is there a specific naming nomenclature required ?
Thanks and apologies if there are other threads that explain the above already !
DS
Apologies if the information is not in the correct format ?
Prospective spec (being built)
Intel i3 NUC with 8gb ram and 120gb mSATA hd
Windows 7
MS media remote
DS
thanks for the help guys ! lol
Patience is a virtue, its considered bad form here to bump your thread in less than 24hSmile
1. This remote?
2. http://windows.microsoft.com/en-ie/windo...=windows-7
3. http://wiki.xbmc.org/index.php?title=Vid...ming_files
thats for the help and will know in the future not to bump before a day !
1) the remote in question is the http://www.microsoftstore.com/store/msuk..._GooglePLA
2) and 3) excellent just what I was after !
....also as I am getting the Intel NUC (IntelĀ® NUC Kit D54250WYK) and that comes with a "Consumer infrared sensor on the front panel" would I be right in thinking I wouldnt need another infra red sensor for the above MS Media remote ?
Thanks again Mayoman Smile
DS
Should be suitable - most IR remotes work on similar frequencies, though you may need to tweak settings per this link (older version though I assume new one is similar)
hmmm after using the regedit from http://xbmccustomregis.sourceforge.net/support.html with net framework 4.5 and the IR driver installed still get nothing from MS black remote. old white xbox 360 one OR harmony one remote.
Running win 7 64 bit.
Any help would be appreciated !
Ok using Flirc so no more remote control issues !
