Full Version: Navigation with Remote Control doesnt work anymore
Hi everyone,
after trying everything I could think of myself I gotta post my problem here.
Problem:
XBMC wont accept commands from an Android remote anymore. With the official XBMC remote none of the navigation buttons do anything. With Yatse I can still play/pause/mute and control the volume (rockers only)
The library works fine. It scans all my movies/TV-Shows and I can start playing them via the remote.
Environment:
- Windows 7 Ultimate SP1 x64
- XBMC (12.2 Git:20130502-32b1a5e)
- All drivers up2date
- Windows Updates deactivated
Failed attempts to solve this:
- Reboot of both Android device and PC
- Reinstalling of official XBMC app and Yatse (After force stop and deleting files/cache failed)
- Triple checked the settings again (even tho it worked fine for months)
-> UPnP: All three options checked
-> Webserver: Allow...: checked; Rest configured properly
-> Remote control: both checked
- Firewall is configured correctly (Even modified the xbmc rule to ask again when something tries to access it. But when I allow it again it still doesnt comply.) Disabling the firewall doesnt work either.
(My) Conclusion:
Error lies within XBMC not the remote app. Tried several apps and several devices (Galaxy SII / Nexus 4)
Here's the xbmc.log after the initial boot stuff (If thats needed please tell me)
Once I started logging I tried to send a few commands with Yatse. (Mute / Volume rockers / Navigation arrows)
22:30:54 T:4352  NOTICE: Enabled debug logging due to GUI setting. Level 2.
22:30:54 T:4352   DEBUG: ------ Window Init () ------
22:30:55 T:3924   DEBUG: webserver: request received for /jsonrpc
22:30:55 T:3924   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:30:55 T:3924   DEBUG: JSONRPC: Calling player.getactiveplayers
22:30:55 T:3924   DEBUG: JSONRPC: Calling application.getproperties
22:30:59 T:3924   DEBUG: webserver: request received for /jsonrpc
22:30:59 T:3924   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:30:59 T:3924   DEBUG: JSONRPC: Calling player.getactiveplayers
22:30:59 T:3924   DEBUG: JSONRPC: Calling application.getproperties
22:31:00 T:3924   DEBUG: webserver: request received for /jsonrpc
22:31:00 T:3924   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:00 T:3924   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:00 T:3924   DEBUG: JSONRPC: Calling application.getproperties
22:31:02 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:02 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:02 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:02 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:02 T:4352   DEBUG: ------ Window Deinit (Pointer.xml) ------
22:31:03 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:03 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:03 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:03 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:04 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:04 T:3344   DEBUG: JSONRPC: Incoming request: {"id":1,"jsonrpc":"2.0","method":"Application.SetMute","params":{"mute":"toggle"}}
22:31:04 T:3344   DEBUG: JSONRPC: Calling application.setmute
22:31:04 T:3344   DEBUG: JSONRPC: Type mismatch in type
22:31:04 T:4352   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
22:31:04 T:4352   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
22:31:04 T:4352   DEBUG: ------ Window Init (DialogMuteBug.xml) ------
22:31:05 T:540   DEBUG: webserver: request received for /jsonrpc
22:31:05 T:540   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:05 T:540   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:05 T:540   DEBUG: JSONRPC: Calling application.getproperties
22:31:06 T:4352   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
22:31:07 T:540   DEBUG: webserver: request received for /jsonrpc
22:31:07 T:540   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:07 T:540   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:07 T:540   DEBUG: JSONRPC: Calling application.getproperties
22:31:07 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:07 T:3344   DEBUG: JSONRPC: Incoming request: {"id":1,"jsonrpc":"2.0","method":"Application.SetMute","params":{"mute":"toggle"}}
22:31:07 T:3344   DEBUG: JSONRPC: Calling application.setmute
22:31:07 T:3344   DEBUG: JSONRPC: Type mismatch in type
22:31:07 T:4352   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
22:31:07 T:4352   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
22:31:07 T:4352   DEBUG: ------ Window Deinit (DialogMuteBug.xml) ------
22:31:07 T:4352   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
22:31:08 T:4352   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
22:31:08 T:4352   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
22:31:08 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:08 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:08 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:08 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:09 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:09 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:09 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:09 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:10 T:5076   DEBUG: webserver: request received for /jsonrpc
22:31:10 T:5076   DEBUG: JSONRPC: Incoming request: {"id":1,"jsonrpc":"2.0","method":"Application.SetVolume","params":{"volume":70}}
22:31:10 T:5076   DEBUG: JSONRPC: Calling application.setvolume
22:31:10 T:5076   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
22:31:10 T:5076   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
22:31:10 T:4352   DEBUG: ------ Window Init (DialogVolumeBar.xml) ------
22:31:10 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:10 T:3344   DEBUG: JSONRPC: Incoming request: {"id":1,"jsonrpc":"2.0","method":"Application.SetVolume","params":{"volume":60}}
22:31:10 T:3344   DEBUG: JSONRPC: Calling application.setvolume
22:31:10 T:3344   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
22:31:10 T:3344   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
22:31:11 T:5076   DEBUG: webserver: request received for /jsonrpc
22:31:11 T:5076   DEBUG: JSONRPC: Incoming request: {"id":1,"jsonrpc":"2.0","method":"Application.SetVolume","params":{"volume":50}}
22:31:11 T:5076   DEBUG: JSONRPC: Calling application.setvolume
22:31:11 T:5076   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
22:31:11 T:5076   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
22:31:11 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:11 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:11 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:11 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:11 T:540   DEBUG: webserver: request received for /jsonrpc
22:31:11 T:540   DEBUG: JSONRPC: Incoming request: {"id":1,"jsonrpc":"2.0","method":"Application.SetVolume","params":{"volume":40}}
22:31:11 T:540   DEBUG: JSONRPC: Calling application.setvolume
22:31:11 T:540   DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
22:31:11 T:540   DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
22:31:12 T:4352   DEBUG: ------ Window Deinit (DialogVolumeBar.xml) ------
22:31:12 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:12 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:12 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:12 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:14 T:5076   DEBUG: webserver: request received for /jsonrpc
22:31:14 T:5076   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:14 T:5076   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:14 T:5076   DEBUG: JSONRPC: Calling application.getproperties
22:31:15 T:4948   DEBUG: Thread Jobworker 4948 terminating (autodelete)
22:31:15 T:1536   DEBUG: Thread Jobworker 1536 terminating (autodelete)
22:31:15 T:4944   DEBUG: Thread Jobworker 4944 terminating (autodelete)
22:31:15 T:1616   DEBUG: Thread Jobworker 1616 terminating (autodelete)
22:31:16 T:540   DEBUG: webserver: request received for /jsonrpc
22:31:16 T:540   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:16 T:540   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:16 T:540   DEBUG: JSONRPC: Calling application.getproperties
22:31:16 T:3344   DEBUG: webserver: request received for /jsonrpc
22:31:16 T:3344   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:16 T:3344   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:16 T:3344   DEBUG: JSONRPC: Calling application.getproperties
22:31:17 T:3924   DEBUG: webserver: request received for /jsonrpc
22:31:17 T:3924   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:17 T:3924   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:17 T:3924   DEBUG: JSONRPC: Calling application.getproperties
22:31:19 T:5076   DEBUG: webserver: request received for /jsonrpc
22:31:19 T:5076   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:19 T:5076   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:19 T:5076   DEBUG: JSONRPC: Calling application.getproperties
22:31:19 T:540   DEBUG: webserver: request received for /jsonrpc
22:31:19 T:540   DEBUG: JSONRPC: Incoming request: [{"id":0,"jsonrpc":"2.0","method":"Player.GetActivePlayers"},{"id":1,"jsonrpc":"2.0","method":"Application.GetProperties","params":{"properties":["volume","muted"]}}]
22:31:19 T:540   DEBUG: JSONRPC: Calling player.getactiveplayers
22:31:19 T:540   DEBUG: JSONRPC: Calling application.getproperties
22:31:19 T:4352   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
22:31:19 T:4352  NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:31:19 T:4352  NOTICE: Log level changed to 0
I hope someone can help me out here. If u need any other information please tell me.
Thanks in advance!
Chris
Sorry for posting this in the wrong forum.
Posted it again in Windows Support
This one can be closed or deleted!
