Full Version: Internet Archive - archive.org
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
@gujal I've merged your pull request and updated the repo.
Users can download the add-on direct from this link:
Internet Archive [Video] v 4.2.7
or from the latest version of my Matrix repo which is available from the link in my signature.
As usual, if you have any issues with the add-on, please enable log notifications in the add-on settings and post a link to a full debug log (wiki).
Perfect I'm going to test it soon. I'm having playback issues on Steam Deck I'll see if the issue persist with this version.
Good to see this addon get some love: thank you all.
(2023-02-11, 02:12)gujal Wrote: [ -> ]
(2023-02-11, 01:13)27hectormanuel Wrote: [ -> ]The file I'm trying to play it's an mkv but the add on is playing a lower resolution conversion
give the webpage url so that it can be looked at
here
Wink
here
Wink
Edit: Various videos play at the exact same resolution like these public domain Willie Whopper cartoons
Compared if I download them to my computer I get a different resolution. My guess is IA plays most files at a different resolution sometimes.
Update works well on Deck. Thank you!
(2023-02-11, 02:13)MetalChris Wrote: [ -> ]@MetalChris
Does the Matrix Repo work with Kodi 20 Nexus.  I just installed the repo (installation went fine), but when I clicked on it I got the "Could Not Connect to Repository" error.
It works on nexus but I had better luck installing the add-on directly
When you say you had better luck do you mean you couldn't install the addon through the repo?
I installed the addon directly through the zip and it worked fine.
Just to see if the repo worked, I installed the repo and then couldn't open the repo to see what addons were in it, got the "Could Not Connect to Repository" error.
Yes, installing the repo was very difficult. I wonder if making a release zip on github might help
MetalChris: could you possibly (at some point) fix the Audio add-on you made for the Internet Archive as well?
It does not work on the Nexus version. Thank you for your continued support.
@MetalChris
@gujal
Yes, it would be great to get the audio addon working again.
(2023-06-10, 16:30)irish666 Wrote: [ -> ]But among the other addons I have is the internet archive video addon.  Now that works fine if you go to "movies" for example and try playing a movie. But running the search option just bring up "next page". Well for instance I know there is a "Nightmare Castle" on Archive. But if you type "Nightmare Castle" into the search option, all I get is "next page." I was wondering if the search option works on later versions. Although if it does, I probably won't use it, if it's a choice between that and being able to use Super Favourites.
Search works in Kodi 20.1/Win 7/IA 4.2.7
I typed "Nightmare Castle" into the search, it brought up several Nightmare Castle results and when I tried one it played fine.
Thank you. Sorry for late reply, I had an issue with my computer and didn't have it for a few weeks. I guess it must be the version of Kodi I am using.
The category menus have disappeared, the only thing remaining on the screen is Search (it still works)
(2023-07-26, 21:22)barney63 Wrote: [ -> ]The category menus have disappeared, the only thing remaining on the screen is Search (it still works)
The entire site has been rewritten with javascript all around. Have to redo the main menu completely.
Search still works as I had coded it 3 months ago for the new mechanism
