Full Version: No connection
Hello
I tried to get the official xbmc remote running on my kindle fire hd. but i got the problem that i write down all the parameters. but when i click on ok i only get the list of possible xbmc connections. and if i try to select the only one i get back to the parameter formular.
I followed all the instructions on https://code.google.com/p/android-xbmcre..._and_later
I also tried to test the xbmc with the url http://192.168.0.100:8080/xbmcCmds/xbmcH...o(120;121)
but this doesn't work it only works if i put 192.168.0.100:8080 in my browser.
What did i do wrong?
Today I started the official xbmc remote again and wanted to try to get a connection again. I get now the I/O Excteption (java.io.FileNotFoundException). But somehow the remote control works now. but I cannot connect to the rest. I only get the "Try again to Connect" button. Why doesn't it work?
Maybe I should try another solution?`I also think that it is a bit slow and complecated to use the remote control and a televsion to play music and go through the hole menu to play something. Isn't there a way to have all of it on your tablet/smartphone without using the television and the raspberry pi just play music and videos?
