Full Version: XBMC Domoticz
I'm working on an addon for XBMC that shows the "home automation" devices configured in Domoticz
It shows their status (On/Off), the value (for temperatures), and allows the user to interact with switches.
You can find a screenshot here
It works fine, with the little tests I can do.
So far, only French & English files are here. (Less than 10 labels for now)
It is available on github here
I must admin I shamelessly copied a large part of "speedfan info" plugin to make this one. I used a bit of XBMC Backup as well.
Except for png files, there is no binary file in this add-on. Only python script & xml files.
Now my questions, how can i generated the other language files without having to copy/paste a lot of stuff from google translate ?
The code still needs a bit cleaning, but more or less it's fine.
How can I submit it to a repo ?
As for submitting, see here: http://wiki.xbmc.org/index.php?title=Submitting_Add-ons
Translations can be done via Transifex ( https://www.transifex.com/projects/p/xbmc-addons/ ), I'm not sure how to add your addon there though (please search the wiki, should probably be in there).
Thanks guys.
I will :
* look at the transiflex for translations.
* make my code flawless and submit it in the mailing list.
Meanwhile, it's available here for those who'd like to test. (Domoticz server required, obviously)
https://github.com/h4wkmoon/xbmc-domoticz
Shame it does not work anymore on kodi 17.6. I tried it, would be really great to see values from domoticz server in kodi. Is there anyway to start continuing this addon again for krypton and leia ? Hope so, my french is not so good and i have domoticz instead of Jeedom.
