Full Version: Mele f10 pro Remote
Hello all.
I got my self the Mele f10 pro Remote, I'm using a mac mini with xbmc most of the remote are working out of the box, but there are still some buttons that i would like to map.
I found some posts with the remote and i can me mapped with Eventghost, but EG dosent exist for OSX.
So does anyone know an other way to map the remote.
Thx in advanced..
Sebski
Well thx, didnt hall that much...
I have a Mele F10 (not the PRO version though). Some of the front buttons I believe are IR only. I ordered a FLIRC and will see if I can map them with that.
Only one button is ir the rest are exclusive for the kernel of mele box if you had a android box you can make a few work with a modification
