Full Version: openweathermap
Pages: 1 2 3 4
Hello everybody Smile
Currently i've no Helix up and running so i couldn't test anything.
@ronie: if you are working on it, can you provide your changes on a public place? I'm still interested working on it as far as possible.
@phil65: this addon provides some additional data (marked in bold in the first post) but those values are not shown by skins, so the skin patch was nessesatry. This was the main reason keeping it away from the repository and only provide it through the forum for "more experienced" users.
@Gerhard S: PIL (Python Image library?) is used to glue the marker on the map tile image. As far as i know its a default python library which was included in XBMC 13. Maybe in 14 its an extra package or completly removed
And for future: its published as open source, so anyone who wants to to work on it, feel free to do so Smile I would be realy happy to see it in any future versions of XBMC/KODI
here the change of default.py is also works under Helix
Weather Widget and 7 day forecast work (Confluence tested)
Gerhard
change in line 19
try:
    from PIL import Image
except: pass
change def create_marker to
def create_marker(x, y, filename):
  try:
    blankfile = xbmc.translatePath( os.path.join( __cwd__, 'resources', 'images', 'blank.png' ).encode("utf-8") ).decode("utf-8")
    markerfile = xbmc.translatePath( os.path.join( __cwd__, 'resources', 'images', 'marker.png' ).encode("utf-8") ).decode("utf-8")
    blank = Image.open(blankfile)
    image = Image.open(filename)
    marker = Image.open(markerfile)
    width, height = marker.size
    x = int(x - width/2)
    y = int(y - height/2)
    blank.paste(image, (0,0))
    blank.paste(marker, (x,y), mask=marker)
    blank.save(filename.replace('.png','_m.png').replace('.jpg','_m.png'))
  except: pass
(2014-10-17, 15:20)Gerhard.S Wrote: [ -> ]here the change of default.py is also works under Helix
Gerhard
change in line 19
try:
except: pass
that´s the wrong way. you should add the PIL dependency in addon.xml.
(2014-10-17, 12:21)Bitboy Wrote: [ -> ]@ronie: if you are working on it, can you provide your changes on a public place? I'm still interested working on it as far as possible.
sure, will put my stuff on my github as soon as i have something worth showing.
i'll be writing it from scratch though (well, based on my wunderground code)
so please don't expect any changes from my end that would be easy to backport.
i usually prefer to write my own code instead of c/p'ing code from other people.
... one exception might be the map code, it's probably worth it to check how you've implemented it. :-)
Hi Bitboy,
this is italian translation.
openweathermap_italian.zip
Hope you enjoy this, bye!
Awesome addon. Now that Wunderground is dead....this could become the de-facto favorite.
With that said, anyone who can fix up a version where the 7 day forecast widget works would quickly become my new favorite person.
Hello everybody
I have the problem - on my device (Gotham 13.2, Android) openweathermap not working Sad
@phil65
I know it is not the right way - but I have not found the PIL addon and do not know the right name
but for the widget and the 7 day forecast it is PIL not needed
@trigrhappy @ponciak
looking in my repo under Weather Addons... http://s.IPTVxtra.net/Repo
Gerhard
put
<import addon="script.module.pil" version="1.1.7"/>
in required section of addon.xml.
Thanks Phil, I changed it and work - in my repo I've also updated
cheers :-) Gerhard
@ronie
As i started i used your yahoo addon and later copied parts of wunderground code for more advanced weather information. So both shouldn't be that different. I think there should be only one addon (with one API key) so if needed i can give you the account for login to the openweathermap site.
As i've seen they reworked the page and maybe there are also a few api changes (as far as i remember the free version only uses the newest api version) so maybe there are some changes nessesary.
thx to phil65 and Gerhard.S for finding a solution for PIL library.
I hope i can have a look at it at the beginning of next month.
@Bitboy
but I not removed try / except, because under helix alpha3 he does not find the PIL Lib
Do you have a Repo Ronie?
(2014-11-22, 15:04)dkplayaclub Wrote: [ -> ]Do you have a Repo Ronie?
main Kodi repo
This has been a great find since WU went down. There are some bugs, but only one thing I really find bothersome. The addon always seems to be one day ahead, It always tells me tomorrow is the day after tomorrow.
Should I update to the "extended" version, even if I don't really want to use the maps, or is this a known bug? If not, what would your advice be?
Pages: 1 2 3 4
