2013-12-21, 01:06
Hi, I just spend some hours to configure my system to get my Philips remote to work with xbmc through lirc, and when I was on it i manage to setup the IR blaster to control the surround system. I did this because my mce-remotes batteries died, and I was to lacy to buy new.
I know this may be the worst written guide ever, but I'm going to rewrite it with better step when I have time!
(I'm running xbmcbuntu)
Philips remote
Sony remote
Mce-transceiver
IR-cables to the mce, used for ir-blast (plugged into the mce-transceiver)
If you have some tips to do some better configs please comment!
Soo
First of all I tested alla buttons on the Philips remote to se which didn't "do anything" when i was on the HDMI channel. This to know which I could use to control xbmc.
Then started record my Philips-tv-remote, and Sony-Surround-remote (IF you don't want to ir-blast don't do anything that i show with the Sony-Remote).
used parts of this guide, with some small configurations: http://alexba.in/blog/2013/01/06/setting...spberrypi/
Either take a keyboard to your xbmcbuntu pc and press "CTRL+ALT+F1" or use ssh (I recommend ssh)
On all code be root/sudo
NOTE: Sometimes when you do the irrecord it's dosen't work, so i re-did it until it worked (READ THE INSTRUCTIONS GIVEN)
My /etc/lircd.conf file
Then to get it working with xbmc you have to config Lircmap.xml and remote.xml
DO NOT PUT BUTTONS IN THE Lircmap.xml FILE THAT DO SOMETHING TO THE TV AS "SOURCE, OPTIONS. etc"
first Lircmap.xml, put this in your file, and remove/add keys you prefer.
then remote.xml
I didn't have so many keys to use, so this is it.
I rebooted and it worked. But i realized a big problem, it went crazy when i changed source to my playstation or watched ordinary tv. Next post
So I copied my files and made some scripts to make it turn off all buttons aside from one (in my case the Blue, which didn't do anything on my channel HDMI1)
And commented out all the BUTTONS (not the other parts) aside from the blue on /etc/lirc/lircoff.conf
My lircdoff.conf
My scripts to control this (change USER, to your computers user)
Put this in it, change USERHTTP, PASSWORD, IP and PORT to your HTTP info (ie: admin:[email protected]:8080)
make it executable (CHANGE USER)
Then to use this script
Put this in it (where it says button choose all keys that do something to your tv, as source (my KEY_SWITCHVIDEOMODE) etc.)
after adress to the script I have "Remote On", shows in xbmc notifications. And "1" makes the script activate all keys (uses lircdon.conf), "0" deactivates all keys aside from KEY_BLUE (uses lircdoff.conf)
This keys are very important that you DON'T have in ~/.xbmc/userdata/Lircmap.xml
Now all you have to do is make irexec autostart
Put this in it (change USER, to your computers user)
Then run
to make it autostart.
If my bad explaining worked, it should run after a reboot. When you press a button that make the tv do something as "Source" lirc turns off, when you hit "Blue" it starts again.
In the next post I'll describe the ir-blast.
Philips remote
Sony remote
Mce-transceiver
Soo
sudo -s
#enter password
# Make a backup of the original lircd.conf file
sudo mv /etc/lirc/lircd.conf /etc/lirc/lircd_original.conf
# Stop lirc to free up /dev/lirc0
sudo /etc/init.d/lirc stop
# Create a new remote control configuration file (One for philips) RECORD ALL YOUR BUTTONS (you'll need it later)
irrecord -d /dev/lirc0 ~/lircd.conf
# Create a new remote control configuration file (One for sony) (SKIP IF NO IR-BLASTER)
irrecord -d /dev/lirc0 ~/sony.conf
#then i put both remotes in the ~/lircd.conf (SKIP IF NO IR-BLASTER)
nano ~/lircd.conf
#copy the sony.conf lines into this also (SKIP IF NO IR-BLASTER)
#and renamed the name,
#from:
name /home.....
#to:
name Philips
#and the same for sony (see below)
# Copy over your new configuration file
sudo cp ~/lircd.conf /etc/lirc/lircd.conf
begin remote
name Philips
bits 8
flags RC6|CONST_LENGTH
eps 30
aeps 100
header 2737 853
one 469 409
zero 469 409
pre_data_bits 13
pre_data 0xEFF
gap 106679
toggle_bit_mask 0x10000
rc6_mask 0x10000
begin codes
KEY_STOP 0xCE
KEY_PAUSE 0xCF
KEY_REWIND 0xD4
KEY_PLAY 0xD3
KEY_FORWARD 0xD7
KEY_FIND 0x33
KEY_UP 0xA7
KEY_OK 0xA3
KEY_DOWN 0xA6
KEY_LEFT 0xA5
KEY_RIGHT 0xA4
KEY_CHANNELDOWN 0xB2
KEY_CHANNELUP 0xB3
KEY_EXIT 0x0EFFF5
KEY_VOLUMEUP 0xEF
KEY_VOLUMEDOWN 0xEE
KEY_MUTE 0xF2
KEY_1 0xFE
KEY_2 0xFD
KEY_3 0xFC
KEY_4 0xFB
KEY_5 0xFA
KEY_6 0xF9
KEY_7 0xF8
KEY_8 0xF7
KEY_9 0xF6
KEY_0 0xFF
KEY_SUBTITLE 0xB4
KEY_TEXT 0xC3
KEY_BLUE 0x0EFF8F
KEY_SWITCHVIDEOMODE 0x0EFFC7
KEY_GREEN 0x91
KEY_RED 0x92
KEY_YELLOW 0x90
KEY_HOME 0xAB
KEY_A 0x6F
KEY_O 0xBF
end codes
end remote
begin remote
name Sony
bits 7
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 2406 570
one 1210 580
zero 612 580
post_data_bits 8
post_data 0xA
gap 44575
min_repeat 2
# suppress_repeat 2
# uncomment to suppress unwanted repeats
toggle_bit_mask 0x0
begin codes
KEY_POWER 0x54
KEY_MUTE 0x14
KEY_VOLUMEUP 0x24
KEY_VOLUMEDOWN 0x64
end codes
end remote
nano ~/.xbmc/userdate/Lircmap.xml
<lircmap>
<remote device="Philips">
<play>KEY_PLAY</play>
<pause>KEY_PAUSE</pause>
<stop>KEY_STOP</stop>
<forward>KEY_FORWARD</forward>
<reverse>KEY_REWIND</reverse>
<left>KEY_LEFT</left>
<right>KEY_RIGHT</right>
<up>KEY_UP</up>
<down>KEY_DOWN</down>
<select>KEY_OK</select>
<back>KEY_EXIT</back>
<one>KEY_1</one>
<two>KEY_2</two>
<three>KEY_3</three>
<four>KEY_4</four>
<five>KEY_5</five>
<six>KEY_6</six>
<seven>KEY_7</seven>
<eight>KEY_8</eight>
<nine>KEY_9</nine>
<zero>KEY_0</zero>
<subtitle>KEY_SUBTITLE</subtitle>
<obc1>KEY_FIND</obc1>
<obc2>KEY_TEXT</obc2>
</remote>
</lircmap>
then remote.xml
nano ~/.xbmc/userdata/keymaps/remote.xml
<keymap>
<global>
<remote>
<obc1>RunScript(script.xbmc.subtitles)</obc1>
<obc2>Info</obc2>
</remote>
</global>
</keymap>
cp /etc/lirc/lircd.conf /etc/lirc/lircdon.conf
cp /etc/lirc/lircd.conf /etc/lirc/lircdoff.conf
nano /etc/lirc/lircoff.conf
My lircdoff.conf
# Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.9.0(default) on Thu Dec 19 18:37:46 2013
# contributed by
# brand: /home/white/lircd.conf
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name Philips
bits 8
eps 30
aeps 100
header 2737 853
one 469 409
zero 469 409
pre_data_bits 13
pre_data 0xEFF
gap 106679
rc6_mask 0x10000
begin codes
# KEY_STOP 0xCE
# KEY_PAUSE 0xCF
# KEY_REWIND 0xD4
# KEY_PLAY 0xD3
# KEY_FORWARD 0xD7
# KEY_FIND 0x33
# KEY_UP 0xA7
# KEY_OK 0xA3
# KEY_DOWN 0xA6
# KEY_LEFT 0xA5
# KEY_RIGHT 0xA4
# KEY_CHANNELDOWN 0xB2
# KEY_CHANNELUP 0xB3
# KEY_EXIT 0x0EFFF5
# KEY_VOLUMEUP 0xEF
# KEY_VOLUMEDOWN 0xEE
# KEY_MUTE 0xF2
# KEY_1 0xFE
# KEY_2 0xFD
# KEY_3 0xFC
# KEY_4 0xFB
# KEY_5 0xFA
# KEY_6 0xF9
# KEY_7 0xF8
# KEY_8 0xF7
# KEY_9 0xF6
# KEY_0 0xFF
# KEY_SUBTITLE 0xB4
# KEY_TEXT 0xC3
KEY_BLUE 0x0EFF8F
# KEY_SWITCHVIDEOMODE 0x0EFFC7
# KEY_GREEN 0x91
# KEY_RED 0x92
# KEY_YELLOW 0x90
# KEY_HOME 0xAB
# KEY_A 0x6F
# KEY_O 0xBF
end codes
end remote
begin remote
name Sony
bits 7
eps 30
aeps 100
header 2406 570
one 1210 580
zero 612 580
post_data_bits 8
post_data 0xA
gap 44575
min_repeat 2
# suppress_repeat 2
toggle_bit_mask 0x0
begin codes
# KEY_POWER 0x54
# KEY_MUTE 0x14
# KEY_VOLUMEUP 0x24
# KEY_VOLUMEDOWN 0x64
end codes
end remote
nano /home/USER/Scripts/remote.sh
#!/bin/sh
scriptdir="/home/USER/Scripts/"
killall -9 irexec
if [ $2 -eq 1 ]
then
rm -rf /etc/lirc/lircd.conf
cp /etc/lirc/lircdon.conf /etc/lirc/lircd.conf
else
cp /etc/lirc/lircdoff.conf /etc/lirc/lircd.conf
fi
sudo /etc/init.d/lirc restart
irexec -d /home/white/.lircrc
cd $scriptdir"tmp/"
wget -q "http://USERHTTP:PASSWORD@IP:PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22GUI.ShowNotification%22,%22params%22:{%22title%22:%22Lirc%22
,%22message%22:%22$1%22,%22displaytime%22:10000},%22id%22:%221%22}"
cd ../
rm -rf $scriptdir"tmp/"*
chmod u+x /home/USER/Scripts/remote.sh
nano ~/.lircrc
begin
prog = irexec
button = KEY_BLUE
config = /home/USER/Scripts/remote.sh "Remote On" "1"
end
begin
prog = irexec
button = KEY_YELLOW
config = /home/USER/Scripts/remote.sh "Remote Off" "0"
end
begin
prog = irexec
button = KEY_GREEN
end
begin
prog = irexec
button = KEY_RED
end
begin
prog = irexec
button = KEY_SWITCHVIDEOMODE
end
begin
prog = irexec
button = KEY_HOME
end
begin
prog = irexec
button = KEY_A
end
begin
prog = irexec
button = KEY_O
end
nano /etc/init.d/startirexec.sh
#! /bin/sh
sleep 10
killall -9 irexec
sleep 5
irexec -d /home/USER/.lircrc
exit 0
Then run
update-rc.d startirexec.sh default
