2013-12-21, 20:07
Hi all,
I'm using RasPi OpenELEC v3.2.4 with XBMC Frodo.
I do my add-on development/modifications on a MacAir Mavericks with XBMC Gotham.
Yesterday I made a few changes to an add-on (Sickbeard XBMC). I added new categories and options to the add-on's settings page, and also added new functionality to the actual add-on.
I did all this on my Mac. On the Mac, with every save to the code, I can immediately see the changes in XBMC and the add-on itself.
However, when I copied the files to my Pi, nothing happened! The add-on functions and looks exactly the same as before. To be clear, I went so far as to delete the plugin's folder (/storage/.xbmc/addons/plugin.program.sickbeard/) - and the plugin still works.
This must mean there's a cache system at play here, although the plugin's addon.xml doesn't require the Common Plugin Cache at all. Still, I tried to rename /storage/.xbmc/temp/commoncache.db, still with no luck.
Could this plugin in fact "exist" somewhere else other than XBMC's add-on folder? To be clear, I'm sure that /storage/.xbmc/addons/ is in fact my RasPi XBMC's add-on folder, since I've made changes to a skin that resides there, and they took effect with no problem.
Anyone know that the hell is going on
